Free Mods...
gabo
Car: 1992 nissan 240sx
degrease the engine, under car, wheels(take them off car and clean the back too)
...cleaning inside and out is cheap...can take a while....and the finished product really gives you a sense of accomplishment.
I did this when my car was out of commission about 2 years ago. now it needs it all over again.
Ghast
Car: 1993 240sx, 2002 Lancer ES, 2006 350z Enthusiast
Ok here is what you do.
You will need:- A cup of water.- one Dirty toothbrush- WD-40- Lots of will power.
K so then you pop your hood. And go to town on cleaning everything. The WD-40 is for lil circuits here and there just a quick lil spray on all of them that see air and slight weather will not hurt them WD-40 = Water Displacement/40. So its not going to hurt anything. just scrub everything you can get too. Get some shop towels to get that EXTRA nasty build up off in the special areas. Maybe get all your lose change and go buy some sea foam ( some people hate this stuff, BUT I LOVE IT ). Sea Foam your car, you can also use it to clean other lil areas in the engine bay. I if you can get the money for it maybe buy a MAF Sensor cleaner its only like 3 bucks. Just spray it and let it dry. That could take a good 4 days of work if you have like ADD.
Hope this helps!
Ghast
gabo wrote:degrease the engine, under car, wheels(take them off car and clean the back too)
You totally posted right before me hahahaha.
Good stuff ^^
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
replace your stock fuel filter with a z32 unit, cost 6 bucks, clutch damp is a good one as well.
stephen240
Car: 95 240SX
SullivanRacing06 wrote:replace your stock fuel filter with a z32 unit, cost 6 bucks, clutch damp is a good one as well.
clutch damp? not familiar?
Razi
Car: Moo
http://garage.projectraine.com....html
stephen240
Car: 95 240SX
what about just getting an auto to manual swap braided steel line?
http://enjukuracing.com/agency...=2_88
or
http://enjukuracing.com/isis-a...=2_88
Both are under 40 bucks!
PapaSmurf2k3
Site Admin
unbolt all your ground wires, sand down the connections, and re-install them. That should take some time, and is a damn good thing to do.
S13CoupeLover
Car: 1990 240sx hatch
Ghast wrote:Ok here is what you do.
Hope this helps!
hmm yeah that's what i've been looking for!!! my engine bay is GREASY/DIRTY!!! lol so i can do that this up coming weekend...wait no it's JCCS. ok maybe some time this week.
these are pretty good.
i still wanna know if i can do anything to make my hood open differently. EX: without having to us the hood opener.
lemon
Car: 1979 rally nova
hood pin kit.... 20-30 bucks.... remove front latch, and use the pins... looks cool ( i think, but i also come from the muscle car world.... so my views are different ) that's really all you can do for the hood
gut the cat.... or tube it....
get some gas treatment, and fuel injection/oil treatment and put them in your car.... really gets some of that s*** out of your car
remove rims.... clean them, spray breaks with lube ect... to clean them out, then clean the brake dust off the back of the rim...and maybe even lay down some paint... some nice gray,black, or smoke wheels would look cool and cheap
if you have a cell phone and have some one who can help you if you ever get a flat... remove spare tire and all the other jacks and s*** from your trunk... you save weight
remove sound deadner
get fast orange engine degreaser... spray on, let sit for 15 mins and whipe off.... gets your engine to look how its suppose to... minus paint chips/scratches....
go to lowes pick up some either hard piping or pvc piping if you want to be really ghetto and rig up a cold air intake.... with your big cown filter...but remember to get that filter as far away from the motor as possible
take your valve cover off and paint it...cheap and looks good
wash the car with soap and water...let sun dray, then put 4 coats of wax on it....
clean up wiring in the engine bay... really most of those wires only need to be re routed....
sleepy eyes if your into that
clean your sensor
$34.99 chrome hose cover kit from pep boys....looks pretty cool and kind of cheap
oil change....15 bucks
change the plugs .... 15 bucks
change the wires.... 50 bucks
break pads ...front.... 24 bucks life time warranty from auto zone duralast gold series.
make a homedepot/lowes lip kit...cheap
....just some cheap / free stuff
S13CoupeLover
man... i don't like hood pins. i've seen and heard of people opening their hood without the use of the latch. like one flips up the headlights and then pops the hood by pulling up on the hood then unlatches it. then also another one where you pop the hood with the latch then you can't open the hood without closing the door first.
but yeah thanx for the ideas guys! i'll be doing some of those probably soon. also i still have to take out the wheel well cover on the inside since my tires are scrapping against there.
Crautz240
Car: 92 240sx Hatch
jeff420 wrote:all i did to my 240 to get lit sleepy eyes when i still had my popups was cut the brown wire. was easy as hell, i was drunk, went outside with some snips, cut the wire, and bam it was done
did the same thing, cept i think i was waaayy more drunk then you were cause i cut the wrong one... then me and my friends laughed for an hour straight cause we realized if it was a bomb we would have been dead lmao
Two-Fortee
Car: 180sx.
Im too lazy to see what was posted above, but my buddy bought garage door strip (that black stuff that seals the door to the conrete) and turned it into a $10 lip. Its surprisingly nice.
I know how stupid that sounds btw, but it doesnt look bad and it never gets a scratch...
89twoforty
Car: 89 fastback
This isn't quite free, but it's not too bad.
Is this what you're looking for as an alternative to the hood propper?
http://www.nicoclub.com/articles.php?id=193537
Cleaning the engine bay/grounds is probably the best cheap mod you could ever hope to do. It takes a bunch of time, but the end results are definitely worth it.
lanerjo
Car: 1990 240SX w/ RB20DET
1993 Pathfinder 4x4
1995 240sx Ka-T
The best free mod you could do is weight reduction... get rid of those unwanted pounds... if it were me i would start by removing the sound deadener and the insulation under the carpet
Gut the interior... remove everything that is not needed... replace everything else
89twoforty
Car: 89 fastback
I wouldn't recommend gutting or removing the sound deadening unless it's a track car. Since it seems it's going to be your daily that will get old really quick.
If you've never taken a ride in a car with no sound deadening I'd do it before even considering stripping a daily.
Nissan240sx_s13
Car: 1990 Nissan 240sx
Ha gut your interior and die like I almost did. Just wait tell you get the money, going cheap sucks.
S13CoupeLover
89twoforty wrote:This isn't quite free, but it's not too bad.
eh not quite. i'me talking more like opening it differently, without using the latch then unlatching it from the front. if that made since... but thanx.
omgjacki
Car: I have a few 240s
Crautz240 wrote: did the same thing, cept i think i was waaayy more drunk then you were cause i cut the wrong one... then me and my friends laughed for an hour straight cause we realized if it was a bomb we would have been dead lmao
Hahaa!
Nis-240sx-san
Car: 1991 Nissan 240SX KA-T
S13CoupeLover wrote:well they want me to be working more on school work and not be thinking to much about my car.
even though i can't work at school cuz i'm thinking way to much about my car...
same here, but I work, but at school all I'm thinking about is my 240
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Touge noob S13
Car: 1991 240SX coupe
Get a Broadway mirror, greater visability, looks cool, and runs anywhere from 10-20 bucks depending on size.
pejsa s-13
Car: 91 HardBody, 85 720
chop your springs?
id like to see pics of your car so we all have an idea of what you got
S13CoupeLover
hold up wrong link
to lazy to post up pics but i believe there's enough there.
here: zerothread?id=367774
pejsa s-13
i posted in your thread but if you need some one to dispose of that beast on your dash...........hit me up lol
abc123omg
Car: '93 240sx KA-T
strip car, loose weight, ditch the fat friends, meet some hot skinny models chicks, instant weight reduction!
S13CoupeLover
pejsa s-13 wrote:i posted in your thread but if you need some one to dispose of that beast on your dash...........hit me up lol
yeah first let me find out how to... take it out. lol
abc123omg wrote:strip car, loose weight, ditch the fat friends, meet some hot skinny models chicks, instant weight reduction!
yeah sounds good. except for the stripping car idea..
bonestock240sx
Car: 1991 Nissan 240sx
im sorry to say, but royal purple isnt that great. AMS OIL FTW
93240cooool
Car: 1993 240sx
why does everyone keep bumping these dead threads?
jeff420
Car: too many to fathom
all i did was cut my brown wire. i was able to run lit sleepy eyes with no extra switch. dont make me go back to popup just to prove it, lol.
