Mettler »
https://forums.nicoclub.com/mettler-u36299.html
Fri Aug 10, 2007 6:52 pm
Hey guys this is nothing new. Adrian from Franklin Cams is who I've been dealing with all this time... you'll notice the cam profile specs as seen on that webpage are the same as the ones I posted up in my "cam options for VH" thread ages ago.
It is with him that I will be grinding the cams I'm designing at the moment, and after a few lengthy discussions on the phone, it has been with his recommendation that I have gone ahead and designed blanks. You guys should just wait and watch this space. Using gas welding to add material to your factory cams doesn't guarantee they won't warp, we've both already agreed machining blanks from billet is going to work out cheaper and more reliable in the long run, else I wouldn't be going to all this effort.
I have to disassemble chamber 1, remove the valves & springs etc... then am taking the head in to get CMM measured with a touchprobe to 0.004mm degree of accuracy, and will be able to finish modeling the chamber and valve positions accurate etc. After that, I can run piston to valve clearance simulations all day long and come up with any cam spec you can dream of, and it'll work with the factory internals.
Adrian won't give you any more information than what he's already told me. If everyone's going to jump the gun and buy elsewhere, I won't offer anything up for a group buy. I'm investing considerable R&D to ensure what I offer up is going to be perfectly suited to the application, I hope this is somewhat reassuring to you guys that the wait will be worth it. A lot of those profiles have been made to work with race engines that run forged pistons and other internal differences. I want to make something that absolutely maximises the potential of the stock bottom end, with the closest possible valve clearances, and mocking it up in 3d enables it to be done to such precision. Many of the profiles that they have available do not necessarily maximise potential in this regard. Please keep this in mind before you dismiss my billet cams in favour of regrinds.
Modified by Mettler at 10:14 PM 8/10/2007
Modified by Mettler at 10:18 PM 8/10/2007
