Clifton wrote:For a street car I think Franklins cams would be my choice.
Mettler, what kind of lift do you plan to run? More than his? Also duration? He has some at 295*. Quite a bit for a street car. I also don't know how much you can increase the ramp rate with HLA's. Might be a reason he is using what he has. Admittedly, I know very little about HLA's so I could be wrong there.
Don't talk to me about duration when you have a VTC engine. Lets talk dynamic compression ratio, lift, and overlap, because it's those three factors which are relevant to designing a cam profile, and those three factors which are changing. Duration will be whatever it ends up being once I've configured the cams to meet my desired DCR.
Clifton wrote:A cam grinder isn't going to dyno an engine with each cam. They know what the stock specs are and what they can get away with. The questions should be, with X cam can I run stock springs, what will the overlap be installed straight up, same as stock? Do you have a cam card I can look at or does the cam come with a card. 6 months ago Mettler didn't know what duration was at .050" and now you are willing to trust whatever he comes up with. Try a steep solid cam ramp rate on an HLA and I'm sure the outcome won't be good. Unless he is designing a shim/bucket set up to go with it.
6 months ago Mettler DID know what duration @ .050" was, but due to conflicting information on the internet there were various values for this spec that did not add up to me. Thankfully I have a curious mind and I like to establish the hard facts, and I'm not afraid to ask questions to further my knowledge, rather than assuming I know it all. Upon doing further research I've actually found out that duration @ .050" means different things when discussing an OHV or an OHC engine (link to an article about this coming in the next few days). I bet you didn't even know that, so I'll thank you to trust me that I'm doing my research properly.
I've completely modeled all the valvetrain components and am waiting to receive my cylinder head back from the metrology calibration service, who will be supplying it with an accurate 3d map of the head & valvetrain geometry, measured using a touchprobe machine. When I say accurate, every surface (hopefully even the ports) will be mapped in 3d to 0.0004mm of accuracy.
What this means is that I'll be able to simulate, in 3d, EXACTLY what is happening in the valvetrain, and when the valve starts opening and closing, what dwell time, etc, and configure it all so that it WORKS to its absolute limits. What this means is that the cam will be developed with 20 degrees advance in mind, so the intake valve opens as early as it's physically possible without hitting the piston, it'll open as fast as possible without any interfere with the valvetrain components, it'll dwell at peak lift for as long as possible, and it'll close as fast as possible without slapping the valve against the valve seat... lastly, it'll be configured to meet a given DCR value to get maximum performance out of the 10.2:1 static compression ratio. Let me remind you that this process is considerably more advanced than what even cam grinders do, and will allow me to gain more precise and accurate timing than what you could figure out with maths, a pen & paper.
I'm hoping to get 12.7mm (1/2" valvelift) out of these cams without there being any lobe to finger rocker interference due to steep ramp rates. Also, the cams will obviously require replacement valvesprings which will be supplied with them should I decide to manufacture and sell them.
I'm doing it right, ok? I'm a New Zealander and you can trust our intelligence and engineering skills to be on the mark. I'm someone who is very passionate about my project car and these motors, and I'm actually hoping to further my knowledge in this area so I can enter into a career in this field. I'm making my own set of cams first, and will prove that they work well and make good power... and after seeing how much hassle it's going to be to do this, I'll add up whether it's going to be worthwhile going through this hassle a few more times for your benefit too.
