Chrispy300 wrote:
No no, I meant for valve clearances. You regrind a cam the base circle is going to be smaller. Can the HLA's cope with that or do you need longer valves/deeper valve seats?
The specs on the cams are as follows...
Stock:
Advertised Duration 240* Intake, 240* ExhaustDuration @ 0.050" lift 177* Intake, 176* ExhaustMaximum valve lift 0.368" Intake, 0.355" Exhaust
Mazworx:
Advertised Duration 272* Intake, 272* ExhaustDuration @ 0.050" lift 185* Intake, 185* ExhaustMaximum valve lift 0.420" Intake, 0.420" Exhaust
IIRC the rocker ratio is something around 1.7:1, meaning a change in 0.075" of valve lift requires a change of 0.044" of cam lift, or a base circle reduction of 0.044" since these are regrinds.
Is HLA/Valve work required? No, the change in base circle is small enough that the HLAs can take it up without worries.
However, when I had my heads done (which Jerry has now) I had a racing valve job done, which basically moved the valve stem tip up once the valve seats and valves were machined. This re-established the proper rocker/cam clearance, and I had that valve height matched on all cylinders. Granted, the rocker then sat at a slightly different angle, but this is also not out of the relm of acceptable by any means.
