FITMENT DATABASE - Post your wheel setup! (no pics with specs = deleted)
S13Teddy
Car: R32 Skyline, S13
1989 Nissan 240sx Coupe
Sportmax 501 16X8 +15 front and rearMegan Track Series Coilovers w/ camberplatesNo other suspension modsDunlop Direzza 195/50/16Front and rear fenders are both rolledClears coilovers fine, no rubbing eitherDon't know if it will clear Z brakes
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
SSR Integral A2 (uber rare, good luck finding 'em )
--16x7+32 front--16x8+38 rear--Spoke design is huge, clears Z32 26mm calipers w/ plenty of room. 30mm should also be fine.--225/50/16 all around w/ KYB AGX+Suspension Technique springs. --No rubbing/touching. --Tires shown: Yokohama ADVAN S4
ArticDragon192
Car: 91 Z32 2+2
- Volks Racing- Diameter : 17s- Width : 10J- Offset : +15- Clears coilovers and brakes- tensions rods, toe rods in the rear- fenders are rolled and have a newspaper pull all around- 245/40-17 all around- Alignment: Camber : -3° all around Toe : 0 toe all around Caster : 10.5 (Needed to clear AICV in rear of fenderwell)- NO rubbing at all
Pics:
inqui-Z-tor
Car: 84Z31, 05A08
Nice idea for a thread .. but it really should be organized by car/model.
Here is my contribution .. for 84-89 Nissan (300ZX) Z31 ONLY
http://wheelshow.redz31.com/
usdm_180sx
Car: 1993 Nissan 240SX base S13
No way I can't believe I missed this!
- Work Equip- 17 - 9 and 10- +16 and +18- High disk, clears z brakes and coilovers- Tein Flex, SPL t/c rods (front) SPL RUCAs and Toe links (rear)- fender modifications? Rolled and mild pull in rear (5mm)- 215/45 and 235/40- Custom made by RB Motoring
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
- Wheel Brand: Volk CE28N
- Diameter: 17"
- Width: F 9 / R 9.5
- Offsets: F +15 / R +22
- Brakes: Stoptech 13" kit (which does fit 17's... reply to above post)
- Suspension modifications: Cage, Hicas Swaybars, Hicas elim, Kei Office XT coilovers, Tein Tierods and Ends
- Fender modifications: Highly rolled and pulled front and front w/ no fender liner up front due to ride height
- Tire Sizes: because they were free 235F/245R... going bigger when I finish with these
- Any other relevant info: don't be afraid to roll/pull your fenders... just take your time and use a proper roller...
And... it was just for fun17x10 +12 on the rear w/ 245 tire
blues14
Car: 1995 Nissan 240SX GTS-t
18"x8" F/R+30 f/rNissan oem 350z touringtires 225/45r18 front 245/45r18 rear Tokico blues with espiler ASD springs no fender mod clears big breaks(r32)My s14
fuse=--action
Car: '91 240sx
Nissan base model 350z "Enthusiasts" wheels, staggered stance17x7.5 +3017x8.0 +33
BF Goodrich G-force Super Sports up front225 45 17
Potenzas in the rear (they came with the wheels, and will be changed to match the fronts soon enough)235 50 17
Clears Z-brakes with ease.Fits flush, no spacers, no rolling/pulling.Had to get shorter sidewalls up front because they loooked like truck tires and because they barely clear the stock suspension.
-fuse.
Cameron
Car: a 240
- SSR Vienna Kreis- 18- 9J F 9.5J R- +24 F +18 R- Clears Coilovers w/ 5mm spacer Front, Doubt it will clear Z brakes, cause as it sets right now at +24 F it rubs on the Caliper...- Suspension modifications in pics are just stock struts with Cut Springs, i Got Coilovers on there now. Will Change Pics when I take some.- Rolled Fender Lips for it to Fit, Will Be adding a More Aggressive Roll To Rear when i Add 15mm Spacers all round.- 215/45/18 All round- Soon Spacing will have +15 added all round for +9 F +3 R.
Blacky Chan
Car: 93 pug hatch
sportmax 002's 16x8 +/- 0nexxan 205/50/16'skts coilovers (clears them)courtesy nissan rucaswickid tunning tension rodsroll on front and back but it really doesnt matter
Touge noob S13
Car: 1991 240SX coupe
- Wheel Brand: Autobahn- Diameter: 15- Width: 7- Offsets: +10- Like most old school meshies, they will not clear Z brakes unless you used spacers- Suspension modifications: Eibach Sportlines with Tokico blues- No fender modifications- 205/55/15-Front 205/60/15-Rear
ashibah83
Car: 93 SUPA BLACK COUPE
- Wheel Brand: Rota d2- Diameter: 17- Width: 8.5- Offsets: +20- not sure about Z brakes, although it lookslike the willclear with ease- Suspension modifications: Stance GR+ coilovers, Full Battle Version Arms- No fender modifications, but if i wanna go lower i may need a roll- 215/45/17-Front and Rear
sviellvoicae
Car: 1992 sil-40
17" 5zigen typhoons +43 all around with 50mm spacers. Tires are Falken Azenis 225.45.17
all pics are the same car. The silvia front with chargspeed kit is how i bought it, so i sold all that and i am now changing to what i want. here is the begining to what i am doing
just ordered thesehttp://cgi.ebay.com/ebaymotors...7.m32
http://www.origin-lab.com/inde...l=180
and the 30mmhttp://www.origin-lab.com/inde...b=180
will post when all is done
kornaz
Car: 95 240sx SE.
- SSR Professor SP1- 18- 10" all around- + 16 F with 8mm spacer (will be +9 soon), +24 R with no spacers (will be ? soon).- Dunno bout the Z brakes, but with spacers up front clears Q45 brakes with some room. Front doesn't clear coilovers without spacers. Running 8mm right now, need 10mm to have about 2.5 - 3 mm clearance. Rears clear.- Megan track coilovers, running max front camber, dunno rear. Camber not adjusted, but when i go 15mm up front, i'll rpolly be 1.5 - 2 neg camber front, and prolly same on rear with spacers, or mad pull. - All fenders rolled. Rear's pulled like 2 - 3 mm.- 225/40 all around.
alex4
Car: 89 coupe, 87 supra
- Motegi Traklite Anthracite with Machined Lip- 15x6.5- +35 offset- No way in hell it clears Z brakes. It's a 15 inch wheel.- No suspension mods, but I think they will look even better with a little drop.- Tires: 195/60R15 Cooper Lifeliner
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Rota Grid OffroadsDiameter: 16"Width: 8"Offset: +10 front and rearDoes NOT clear Z brakes. Clears coils fine.All control arms are stock.Fender roll required front and rear for my tire size.225 50 16 Falcon Azenis RT-615s front and rear.
My camber settings as pictured are -2.6 degrees on each front wheel, and -2.5 degrees on each rear wheel. The fenders will need pulling if you want to run less camber. Im thinking about adding some 10 mm spacers to the rear to push them out slightly further.
/edited, better pictures added/
Modified by FlatBlackIan at 12:41 AM 7/6/2008
slik_s13
Car: 1990 nissan 240sx hatch back
- Wheel Brand- gramlights 57 maximum flat black- Diameter- 17- Width- 9- Offsets- +12- Does it clear z brakes and coilovers- i dont have z brakes, so dont know.i do have kts coilovers and it clears them just fine.- Suspension modifications- i went as low as i could get the coilovers togo with out giving it a really rough ride, still pretty rough but not rough enough for me. what i did was take out two collars from the coilovers. running stock sus arms for now adjusted them as much as possible so that way im not runnin so much camber, a big difference that made really need to get the arms ASAP.-What fender modifications- i did a slight roll in the front and the back was a little more of a roll. also folded the the inner seem in the front fender wells that the tires always rubb on(right by the coilover). tucked my harness so theres no rubbage there- Tire Sizes- 215/40 all around- Any other relevant info. noneon to the picsstill need to paint itcant really see the wjeel to well in this one.
danielsan
Car: 1991 240sx coupe SE
- Datsun 280z turbo wheels- Diameter - 15"- Width - 6"- Offsets - +10mm- stock suspension- running 195/60/15
Modified by danielsan at 9:28 PM 7/2/2008
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
-Z32 OEM non-turbo rims painted gold-225/50/16-+45 Offset-Not sure about the Z32 brakes, but I am pretty they will fit. (I hope so because i plan on putting them on)-Megan Street Coilovers-The front wheels rubbed on the coilovers so i got 30mm spacers and they clear fine, the fenders just need to be rolled
drifter92
Car: 1995 Nissan 240sx Small BLock Chevy V8 5.4L
1990 Nissan 240sx Coupe SOHC Auto Wrecked Project Car
- Sportmax 962's- 18"- 8.5"F 9.5"R- +42 F +35R- All clear- Stock old suspension- Stock fenders but i need to roll the back for hard bumps- 225/40/18 Front 245/40/18 Rear- No spacers
jibe
Car: RS13 RB26 big singled
ZG flaresSportmax 002 15X8 ET0 F and R5mm spacers on front (no front spacer on pics)35mm spacers at the rears205/55/15 F225/50/15 R
smurf13
Car: 1992 Nissan 240SX fatback
elite17 F&R9j F&R+15 F&Rclears coiloversmegan street coilovers and RUCA's225/45's F&Rrolled fenders
3.5 degrees of camber with 0 toe F&R
92SR20S13
Car: sr20det-s13
- Vesta Eins Kahn.5- 18"- 8"Fronts 9"Rears- +35 Fronts +38 Rears-215/35R18 Fronts 245/40r18 Rears- Gab struts with RSR springs-Dont have Z brakes on yet but will install coilovers and brakes with 25MM spacer up front and 15MM in the rear.
mrdicks95se
Work Euroline DH18x8 +36 (7mm spacer = +23 effective) 18x9 +38 (25mm spacer = +13 effective)225/40-18 front and rearTokico Illumina/GC, oe spec camber and toeRear fender rollNot sure on z32 caliper clearance
mrdicks95se
Tenzo Type M19x8.5 +1719x10 +22215/35-19 front245/35-19 rearIllumina/GC, oe spec camber/toeRear fender roll req'dClears z32 and any other caliper. i'm currently running z32 calipers with 13.1" cobra rotors.
esahuque
Car: 95 240sx KA-T, 04 frontier
- Motegi Touge- Diameter-17" - Width-9"- offset-+24 all the way around (5mm spacers makes +19)- clears coil overs, N\A on Z breaks- Coilovers, RUCA's, rear toe arms, front camber plates- rolled F\R slight pull in rear- 225/45/17
Modified by esahuque at 8:27 AM 2/28/2009
SketchyRollin564
Car: SR hatchback in the werks
-z32 TT wheels on s14-Rears: 245/50/16 on 8.5" wide wheel, not sure on offset, i think its +35-Fronts: 225/50/16 on 7.5" wide wheel, +45 offset-Front tires rub the strut a tiny bit, but i just used these little washers as spacers, and its fine now, so 5mm spacer will easyly fix problem-Stock struts, Tein lowering springs-Not sure on clearing Z brakes without spacer
esahuque
::: update from previous post :::
- Motegi Touge- Diameter-17" - Width-9"- offset-+24 all the way around (15mm spacers up front makes +9) (20mm spacers on rear makes +4)- clears coil overs, N\A on Z breaks- Coilovers, RUCA's, rear toe arms, front camber plates- rolled F\R hard pull in rear- 225/45/17
Gabes13
Car: rb20det s13
- Brand: Sportmax/xxr 962- Diameter: 17" - Width: 9"- Offset: +35 (25mm spacers front and back, so +10 respectively) - Don't have Z brakes so don't know- PBM coilovers, rucas, tension rods and tie rods - All fenders rolled ONLY- 215/45/17 all around
camber:-2 deg. front -3.75 deg. back
Modified by pandapants at 9:03 AM 1/18/2010
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
- 5Zigen Typhoons- 17"- 8" Front / 9" Rear- +27 Front / +35 Rear- Clears Z Brakes (No Idea on Coils, but most likely. There is plenty of room!)- Eibach Springs on Tokico Struts- Slight Fender roll, but did not have to do with these wheels- 225/45/17 Front / 275/40/17 Rear
- The front tires are way too skinny. I'll be trying a set of 245/40/17 (the ones that came off of the rear wheels when I put on the 275's). All the pics are with the 245's on the rear except the last 2. I just got the 275's on today!
The 275's! Much better than the stretched look in my opinion...
Modified by ElNegro at 7:51 PM 4/8/2009
