FITMENT DATABASE - Post your wheel setup! (no pics with specs = deleted)
yokota180sx
Car: 1997 Stagea RS4, r34 front
::::MOD EDIT::::::::YOUR POST WILL BE DELETED UNLESS IT CONTAINS FITMENT PICTURES AND ACCOMPANYING DATA::::
This is to help everyone that doesn't know what XXX offset and XXX size looks like on XX chassis.
Post your vehicle from as many helpful angles (limit to 4 pictures please) Front, side, and looking down the side of your car from the rear and front.
Post the following information in this format, using a / to seperate Front / Rear.
- Wheel Brand - Diameter (16/17/18) - Width - Offsets - Does it clear z brakes and coilovers (if you dont have Z brakes don't answer unless you know for a fact) - Suspension modifications/coilovers/springs and struts (not sway bars, not stiffening, im talking arms that were REQUIRED to get your setup to work because of camber/toe problems etc etc) - Are there any fender modifications? if so what? - Tire Sizes - Any other relevant info
Guys, please keep idle chat, out of this thread, it's NOT for discussing setups or asking questions.
Also, please post ALL the required information or your post will be deleted!
Take the 5 minutes and do this right, it will help everyone in the long run!!
yokota180sx
1. Weds Farmas2.173.84.+8 With 20mm spacers front and rear5.No on both accounts unless you have spacers6.Coilovers, rear upper control arms7.Both front and rear fenders rolled and pulled8.225/45/17 (if i remember right)
Modified by yokota180sx at 8:13 AM 7/18/2007
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
good thread yokota180sx. nothing special, heres....1. sportmax 504's2. 18x83. +32 up front, +27 in back(5mm spacers)4. dont know about z32s, but ill know soon.5. coilovers, toe control, rr adj upper control arm6. no tire rub, no fender contact7. 215-35-18
AmoebAssassin
Car: 1991 Base fastback 5spd, black
Awesome idea Grant, this thread is so f-ing stickied.
MicroMNky
Car: '96 240SX
- JIC Magic J-Force 5- 17 inch- 9 (front and Back)- +15 (front and Back)- Clears my STANCE GR+ Pros. - RUCA's. - Slight rollage on the rear. Fronts could use a slight roll if I decide to go lower...which I will. - 225/45's
cmfireman
Car: '96 Nissan S14 SE
- Racing Hart C5- 18" - 7.5" (all 4)- +35 (all 4)- All Stock Suspension- 225/40/18
Basically just showing that +35 on an S chassis doesn't cut it.
KoukiRydr
Car: s14a
•Grenade GX-01s•17 front and rear•9J front and rear• + 15 all around• Clears Nismo G-attack/R-tune coilovers• no other suspension yet•highly recommend to have rear fenders rolled, as i can not got lower on them• 235/45/17 all around
Sorry for crappy pictures, will get some during daytime
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
- 5Zigen FN01s- 17 - 8- +35- Clears Z brakes, won't clear strut with 245/45 tire without a 5mm spacer, i'm using a 6mm- KYB AGX/ Sprint Springs, Cusco RUCAs, Camber -1.7fr, -0.5rr- front roll and very slight pull- 245/45 all around
-Dan
adrianfromthecastle
Car: 1992 Nissan 240sx
- SSR SP1 Professors (the old school ones before they were bought off by Tanabe)- 17"- 8/9 (f/r)- +24 (w/ 10mm spacers, making them actually +14)- have no clue on z brakes- hks hypermax coilovers- fender roll on all 4 fenders (no pull needed)- 215/45 ; 225/45 (f;r)
adrianfromthecastle
- Enkei #92- 15"- 7- +0- will not clear z brakes- 205/55
ArticDragon192
Car: 91 Z32 2+2
K, I'll be the first flush Z32 here, lol.
Front only for these, rears stick out like mad, so not showing pics of that.
First up:MB Motoring Weapons18*9 +15235/40-18Around 2° of camberRoll necessaryLowered on Tanabe GF201 springsClears suspensionClears brakes
ArticDragon192
Car: 91 Z32 2+2
Next up:Uras NS-01s17*9.5 +15255/40-17 AzenisLowered on Stance coiloversClears coiloversClears calipers-3° camber0.0 toe10.5 caster with adjustable Tension RodsRender roll and slight pull necessary
audtatious
5th Gen Maxima (2k2)
- Infiniti G35- 18" - 8"- +30mm- Needs slight roll of passenger rear lip- 245-40-18 - Eibach Pro kit w/Illumina's
Clawhammer
I guess for the S13 guys?
1. Nissan 2. 163. 6.54. 40mm5. Clears coilovers and zbrakes6. Stance GR+ pro's, SPL camber/toe/tension rods (not required)7. No fender mods8. 205/50/16
austins240
Car: 93 240SX HB, 89 Rolla GTS
- CST D-Spec- 17 - 9.5- +15- easily clears Z brakes- K-sport coilovers, barely clear in front.- front/rear roll + (pull reccomended or widebody)- F: 235/40 R: 235/45
I have RUCA with aprox -2.5* (need adjusted now fenders are F!*@ed) and front is approx -1.5*, also needing adjusting.
Modified by austins240 at 4:28 AM 8/7/2007
Modified by austins240 at 4:29 AM 8/7/2007
Soravia
Car: 2003 Audi A4 1.8T
89-90 240sx stock 15x6 wheelsEibach Pro 1" Drop with KYB GR-2205/50/15 tiresPlenty of fender gap.
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
1. Falken Hanabi's2. 173. 94.+20 no spacers5. sold the car before I put the calipers on6. Tein SD 7. Rear fenders rolled8. 235/40/17
slyedog240sx
Car: 93 240sx se coupe, 05 grand cherokee HEMI Power
asa jh2 18x7.5 45mm offset kyb gr2 with tein s tech 215/35/18 all 4. When due for tires will change rear to a 225/40/18 .
Broadfield
Car: 1992 240sx
5 Lug ConversionStoptech 13" Brakes Front (Only 18's or bigger will clear these)Z32 Brakes RearWedsSports TC-005's 18x8.5 +32 245/4018x10 +44 275/35Cusco CoiloversRolled Quarters
kirk
Car: 1993 240sx
SportMax 501's 16x8+15 front and rearFalken FK452 205/50r16 front and rearStance Basic coilovers (clears them by a mile)SPL RUCA'sStock fenders (no mods at all... need a roll to go lower safely)Front -2.3° camber, 5° caster, 0 toeRear -2.0° camber, 0 toe
eds13
Car: 89 240sx Hatch, 07 Armada LE, 91 Skyline GTR
- Work Vs- 18- 9 up front, 10 out back- +5 up front (8mm spacer being used) and +13 rear- needs 8mm spacer to clear z brakes, clears coils fine- kei office coils in the front, tein HA in the rear. No other suspension arms!- roll and pull front and rear, decent in the front. and i need to pull the rear some more- 215/40/18 and 235/40/18
RB_Seth
Car: 92 240sx RB25
91 240sx LT1
95 240sx 280k mile DD
5Zigen FNO1R-C18x8.5 +30 front18x9.5 +35 rearclears all Z brakes easilyStance coilovers, rear suspension arms to correct allignmentwill need to roll fenders to go lower225/40R18 front 255/35R18
more pics here http://www.cardomain.com/ride/2622869/1
sr20power
Car: S14 Zenki
5Zigens FN01R-C17x8 +25 front17x9 +35 rearDon't know about Z brakesTein HE coilovers, Cusco Rear Upper Arms, -1 degree camber all aroundNo roll or fender modication unless you go lower225/45 all around
sr20power
Car: S14 Zenki
Works XD-917x9.5 +17 all aroundDon't know about Z brakesTein HE coilovers, Cusco Rear Upper Arms, -1 degree camber all aroundRear's have been rolled...will lower eventually215/40 all around
SWAT Team S14
sr20power has the exact same setup as me, so save from being redundent i thought i'd add a car i saw on another site......the body work on this car may leave something to be desired, but this is a wheel thread, right? for s14 owners, this car is the epitomy of tire stretched, big lip, low offsest wheels
wheels: work vs-kfsize: F- 18x9.5 +7(effectively +0 with 7mm spacer to clear caliper).R- 18x10 +7
tires:F- 225/40/18 Federal ss595R- 235/40/18 Federal ss595
stock fenders, with a a roll/pull in the rear...
phanatikz32
Car: 1991 NA to TT z32 biatch!
- Sportmax 006's - 18x8.5 front 18x9.5 rear- +35- clears z brakes i own a z- suspension is 100% stock hoping to change that before january - no fender mods- 275/35ZR 18 (REAR) 245/40ZR 18 (FRONT)
WidebodyZ
Car: X300 LWB Vanden Plas / W203 C240 Luxury Sedan
1991 300ZX 2+2 TT
Post the following information in this format, using a / to seperate Front / Rear. * F / R * WORK VSKF / WORK VSKF *18" / 18" * 9" / 10.5" * -3 / -19 * Would not clear stock front calipers..I had 2mm of clearance with 6 piston AP's...rears clear all through the millennium - suspension clearance no problem. * Coilovers, all adjustable arms. * Front fenders are Final Konnexion wide/vented, rears are 75mm TetzuAero over fenders. * Falken RT615 225/40/18 / Falken RT615 245/40/18 * I would hvae loved to go lower, but speed bumps at my housing complex limited me. Camber easily correctable with the arms.
SLde_Show_Enthusiast
Car: 95 240sx
here's daytime pics of my daily:american dream!
wheel specs:F- 18x9.5 +7R- 18x10 +7
Tires:F- 225/40/18R- 235/40/18
alignment:F- -3 camber, +7.5 caster, 0 toeR- -3 camber, dont know the rest because of stock rear arms(didnt feel like swapping those over from the track car).
heres some more on the track car when it was in commission... :-/
Alignment:F- -3 camber, +8 caster, 0 toeR- -2 camber, stock caster and toe(aftermarket toe rods).
Dr. Moreau
Car: 1996 Infiniti Q45
1990 Nissan 240SX
plz. excuse the lack of good paint. i'm poor.
wheel specs:Work Emotion XT7F- 18x9.5 +12R- 18x9.5 +12
kts coilovers, spl t/c rods
alignment:F- -3 camber, +8.6 caster, 0 toeR- -5L/-4R camber, 0 toe
yokota180sx
1997 Nissan Cedric (Q45 resolves same fitment for y33)
Leon Hardiritt Orden 19x9 -25 (-5 with 20m spacer)s13 coilovers and LCA with maxed out camber plates225/35/19
19x10 -6 (i think)S13 rear coiloversRUCAs that are almost maxed out for cambertoe rods rear and front were both pulled and rolled.
