I know it has taken me far too long to get my car tuned by a professional on a dyno. Up to this point, I had only done street tuning on flat, vacant, country roads with good success for being a novice/intermediate tuner. I never knew how much the car put down though.
So we strapped it to the Superflow dyno and Steve Kan (
http://www.kantuning.com) started going through my settings to make sure there wasn't anything out of the ordinary. The first question he asked was, what kind of injectors do you have (referring to my lag settings)? I told him Deatschwerks and I input the lag numbers they provided with the injectors (650cc). Steve said the car couldn't get the AFR up to 14.7 at idle because the lag settings were not accurate for the injectors. He input lag settings from a Mitsu injector, which is what the injectors originated as, and he was able to get it to idle properly. However, changing the lag settings has a direct correlation to injector duty. I didn't know this was was so dramatic until he was only able to extract 420 whp at 16 psi on a T04Z. For this power level, the injector duty was at 85-90%. He tried manually increasing the injector duration, but the AFR did not drop at WOT so he was confident that it was running out of fuel either via the injectors or fuel pump.
I have a Supra TT fuel pump and at 16 psi boost, it should pump 250 lph (4166 cc/min=694 cc/min/injector). IMO, the pump has plenty of head room above 420 whp. I have contacted DW about the injectors and how I was surprised and obviously disappointed in not being able to even hit 500 whp before the injectors maxed out. Has anyone else had experience with DW injectors not flowing what they are "rated" for? I'm hoping someone from DW can maybe chime in on this to help explain.
I will post a video later.
