Steve Kan is a pretty methodical guy and doesn't know what he's walking into with anybody's tune, so he goes through all the settings to check that they are reasonable before gradually adding boost, fuel, and timing. He was doing the same with my tune when he saw the strange injector settings and adjusted them back to levels that were realistic (i.e. the car could idle at an AFR=14.7 instead of 12.5). Any decent tuner will do this to cover his own a$$ and protect his reputation. I respect him for this.RustspecS13 wrote:I know you were there to fine tune, but did you do any pulls with out touching the tune? Why did you mess with the basics of a tune thats been at pretty high boost level on the street with good AFRs? I'm not sure I'm getting the problem. IE bad/small injectors or a incorrect tune/settings..
~Alex
Dont know how true it is but ive heard that low impedence injectors idle better than high impedence injectors when there that large. 1600cc's are big. Ill probably be getting the same thing next year as soon as I sort out the kinks for this year.Darius wrote:Here are my injector calcs based on the fuel injector calculators for 750HP, BSFC of 0.60, baseline fuel pressure of 43.5psi and 750HP crank HP = 933 cc/min x 1.47 for ethanol = 1371 cc/min injectors.
Injector Dynamics 1600cc/min makes a high-impedence top-feed injector, but a set will run nearly $1,400. Youch! Time to go look at the low-impedence resistor box thread
http://www.injectordynamics.com/ID1600.html
What diff do you have? What RPM are you launching at? What RPM are you shifting at? What are the drag radial size? Etc etc etc....Darius wrote:I totally agree with you guys. It should be faster, but even if I shave 0.4 seconds off of my best 60-foot and cut a 1.8, I am still only running a 13.0 ET, right? Or does a quicker 60-foot magnify itself in the overall ET? The diff played a large role in lack of traction off the line, but I still feel like it is lagging for the first 60-feet until the turbo spools.
It ran a 14.7 @ 94 mph with a stock turbo and all-season tires, so after upgrading EVERYTHING I thought it would pick up more than 1.5 seconds...
BTW, reaction time is not included in the ET.
Diff is a J30 VLSDRamius83 wrote:What diff do you have? What RPM are you launching at? What RPM are you shifting at? What are the drag radial size? Etc etc etc....Darius wrote:I totally agree with you guys. It should be faster, but even if I shave 0.4 seconds off of my best 60-foot and cut a 1.8, I am still only running a 13.0 ET, right? Or does a quicker 60-foot magnify itself in the overall ET? The diff played a large role in lack of traction off the line, but I still feel like it is lagging for the first 60-feet until the turbo spools.
1. Diff is/was close to mine, I am/was using a Z32 diff.Darius wrote:
Diff is a J30 VLSD
Launching at about 4000 rpm and feathering the clutch so it doesn't bog.
Shifting at 7400 rpm. Redline is set at 7500.
DR's are 265/40/18 (@16 psi)
