So, not really a race car update, but racecar adjacent.
Since I began racing way back when, I have been toting my electronics gear in a combo pelican hardcase/backpack. Back in about 2016, as the team grew, this method went from poor to awful..... We kept adding gear to the bag, and at Gingerman we reached a braking point.
organizing 2 display tablets, 2 Mobile hotspots, 2 live streaming cameras, 4 in car radios, spare radio harnesses/helmets kits, a pit headset, and a whole fleet of chargers, and trying to fit it all nearly sent me into a fit of rage. It was a huge hassle, and the chances of breaking something were too high.
Before it got pushed into the corner with all the other race stuff until the week of the next event, I decided to do something about it.
I looked at lots of options, from cheap to expensive. After much thought, I decided the best option was to separate the radio gear from everything else, and build out 2 Apache hard cases.
I got the first laid out, cut, and packed. It took way longer than I expected, but was totally worth it.
Bottom layer holds the spare harnesses and programming cables that are rarely used.
Middle layer is essentially a separator with a few cuts for the really deep items.
And the top is the regularly used items.
I'm a little worried about the breakaway foam coming apart more, and I would have preferred solid cutaway foam for all sheets like the separator, but it is Hazard Fraught after all. I found the tearaway block were annoying to tear, and I ended up using a snap knife anyway. Only time will tell.
I will build out the camera/telemetry case later. After scrounging up every charge brick and cable the team had to do overnight charging I felt it was time to streamline that as well. Sadly the 6 port USB charging hub I ordered shipped late and won't be here for a few more days.
