Everything is set if you want to order your R32 GT-R LSD 4:11
superuber
A qiuck way to tell would be to go out and measure the rear studsof the diff. These are the one's on the rear cover. That would tell you quickly and precisely. Measure outside to outside of the studs that go into the rear bushings. Compare that to your ebay diff. If the distance is the same, great if not, buy a lampshade!
Que-45
Car: 03' Y34 Black/Black
I
superuber wrote:A qiuck way to tell would be to go out and measure the rear studsof the diff. These are the one's on the rear cover. That would tell you quickly and precisely. Measure outside to outside of the studs that go into the rear bushings. Compare that to your ebay diff. If the distance is the same, great if not, buy a lampshade!
I crawled under my car and measured the length between the 2 rear studs and they are the same. The space between the rear studs is 5-1/4 '' exactly on both diffs. What about yours?
superuber
Well, thats great news! Sounds like you are go! I guess Red was right. The one I got must be a R34 or something. Thanks for measuring and clearing that up. Got an extra lamp shade?
redmanfx
Car: 92 Q45a
The GT-R guys in Canada got back to me and could not Identify that P/N on the E-bay thread, at least not the ones who checked their e-mail yesterday. They gave me other P/N's but couldn't find the one in the e-bay thread. Funny that it fit Que-45 but not yours. ????
Que-45
I lifted the Q up today and had the skline diff under there with me to compare to my stock rear diff. everything looks the same except the skyline diff has 2 abs sensors on the axle flanges and the Q diff has one inside the diff near the companion flange. I guess I'm going to wire the 2 together and slpice into my existing abs wires since the Q only has 1 abs sensor. I'm going to attempt this swap tomorrow, I will take comparison pics for you guys once I get the stock diff out. superuber, are you still not able to post pics up? I'm really curious to see what diff this guy sent you. What are the dimensions of it? How much bigger is it than your stock one? I'll let you guys know how everything goes. Something is telling me It's not going to be straight forward though.
sheadee240
Are all 6 bolt r32 w vlsd bolt in exept for the input flange? Are the speed sensors plug and play for a 94 Q w tcs?
GeNYC07
Car: 2000 Infiniti Q45 ANNIVERSARY EDITION
I recognize that cat anywhere!!!! arn't you on the pinstack board???? Go figure same taste in phone same taste in car.
Hi Scott
sheadee240
I have a 94 q45 t w tcs I understand that I will have to swap my companion flange and swap a j30 speedo (I actually already have one hanging from the j30 diff in my 240sx which isn't connected)I am confident from what I have read that it will bolt in and rip, but will my tcs still work with no warning on the cluster?Thanks
sheadee240
Wes?Anyone?Thanks in advance.
