maxnix wrote:Which is why you need to learn about the VH45DE to be an informed owner and why you need to hire compentent help when you don't have the knowledge or tools.
The FSM, TSB and this board are a great resource. Learn from them by researching and reading, especially all posts by Q45tech.
Brian is as usual, correct.Some of us are mechanically inclined, and have exerience in wrenching, others go further and understand and can diagnose/repair the many electronic components in our beloved Qs. Others are newbies, some in the most absolute in terms. While I see that many of those who write here asking for guidance and help are younger guys, usually with limited budgets, we can all learn here. I know I have.
So newbies, including mexpelon83, take the time to read many posts here, even if you think they may not pertain to your issue. You will learn a lot, much of it useful to you sooner or later. Learn also how to use the search button. While it's a little difficult at first, once you get the hang of it, it's a great resource. Of course, you'll need tools and diagnostic equipment, so if you don't have them, accumulate them over a period of time just like the rest of us have, and most importantly, learn how to use them properly (DON'T use pliers on most fasteners, for example). Learn the terms, and learn to understand the procedures outlined in so many places in this forum.
But also remember Clint Eastwood's famous dictum: "A man's got to know his limitations". When you can't easily diagnose or repair a problem, bite the bullet and take your car to an experienced and capable Q45 technician, and not to just any "repair shop". Don't nake it worse when you have no idea of what you are doing, and don't resort to "quick fixes", like radiator "stop leaks", etc. If and when you do take your Q45 to an experienced Q45 technician and get it repaired properly, always ask what the problem was, what caused it, and how it was fixed. File it away in your memory bank for future use, and to help others here when they encounter the same problem you did. Making notes helps.
Finally, when you do have a problem, and resolve it one way or another, don't forget to post your experience and its resolution here. It may save others the same headaches you had, the same way others have helped you here. We really are all in this together.
PS: Not aimed at anyone specifically, but in general, for those who think it's "kewl" to write poorly, save the teenage texting abbreviations for your friends (hint: "u", "r", "2" and "4" are letters and numbers, not words), and learn to use the shift key for upper case letters, and some basic punctuation. It makes it a lot easier to help you if we can understand what you write here, and don't have to wade through juvenile jargon that might make you look like you don't really care what we think of you. That's not a productive way to get help. A little respect and consideration goes a long way. Save the "screw you" attitude for your buddies who you don't need to bail you out of a jam.
