mexpelon83 wrote:I am thinking of buying another one and try to fix it myself.... I like these cars.
Ok, this would be a good time to bring up the chain guide issue with you.
In the 90-93 series, the timing chain guides were backed with a plastic, not unlike a lot of other manufacturers at the time. Unfortunately, over time, degraded oil (from careless oil change intervals, heating, etc) reacts with the plastic, making it brittle and susceptible to breaking - not always a good thing, heheh. The timing chain then skips and drives pistons into valves - kaboom - sudden death. This can happen at any time, even on startup.
So, every 90-93 owner eventually MUST replace the chain guides with the newer metal-backed ones or he'll fubar his motor - you included. The repair runs somewhere over $1000.
Sorry. But let's get it running first. Meanwhile, read everything under "Chain Guides (CRITICAL for 1990-1993)" on Q45.org:
http://www.q45.org/techhelp.html
