Tried it rightnow and it didnt work.1990QOwner wrote:Sounds to me like some sort of an electrical problem. Try re-setting the electrical system. Do this by disconnecting one of the battery terminals for 30 min.
I had it running on parking for 30 mins to let it warm up. When I was going to test drive it and changed gear from P to D the car just turned off no noise nothing. It just turned off. I tried to turn it on again, it will crank up but I cant get it to run again. I tried what 1990Qonwer suggested but still no run.maxnix wrote:Neutral switch? How did it die when you engaged D?
Let's see ...elwesso wrote:Sorry im late to the thread. Is there any way I could get a synopsis of what's been checked so far?
1. FPCU checked and replaced with a working OEM unit.elwesso wrote:Sorry im late to the thread. Is there any way I could get a synopsis of what's been checked so far?
Question on the MAF on the sensor. there is a white place inside does that have to be solid white or does it have like a light gray line?Fridge wrote:My vote is still the maf. Mine acted just like this and would run fine I would get out at the gas station and when I got back in no startie. I bought a connector off of ebay and a maf from a member here and it has been fine ever since.
No Code? If it's been checked properly (only turning the screw on the ECU one time before reading the codes) then my guess is that it is a bad fuel pump or faulty FPCU. I see that the fuel pump wasn't replaced with the FPCU. Check the codes again and if there are still none I'd be grounding the fuel pump to see if it will run for more than 30 minutes.mexpelon83 wrote: ....2. ECU checked with a Code "55" result.
Ok, I had someone come and check it but according to people in the forum they said that it sounds like it was not checked correct so......elwesso wrote:no mention of fuel pressure checked, like goody said. Check fuel pressure, and report back.
Ask the tech if he was in on the original training in 1989. If not, he has probably never seen a VH45DE and will be next to useless. A lot of Nissan techs think Infinitis are G35, I30/35, QX,..... i.e. - rebadged cars with which the are faimiliar or have similar engines.mexpelon83 wrote:I am going to tow the car to a nissan dealership since its the closest. I called before taking it and they said that they have to Infiniti specialist there.
Well said Wes.elwesso wrote:Here is my honest opinion.
Unless said technician has real diagnostic experience on G50 they are going to be useless. I am always in favor of NICO + motivated member is GREATER THAN an average to slightly above average technician.
As long as I had it the car has never over heated but I dont know if it did with the previous owners.1990QOwner wrote:That sounds very interesting. Are they going to stoink you with a $500 bill now? Has the car ever been overheated or anything like that?
You aught to ask them if there is any way that it can be covered on warranty if it is something that is really defective. Keep us posted. Good luck.
Remember my comment. What if we put this in the line between the fuel filter and engine?AlabamaDan wrote:Too bad you can't just mount a little fuel gauge on the wheel well and have it permanent or something. Sounds easy enough.
After I posted that I was thinking that a gauge on the interior might be more appropriate, but I've never seen anyone add extra gauges to a Q.Q45tech wrote:Unfortunately most low fuel pressures show up underload when the injectors are really open................... 4,000-7,000 rpm. Inside digital psi gauge is the proper solution.
