WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Mar 31, 2004 4:49 pm
Add a few lbs of boost...with your A/F numbers it looks like you could safely add 2 more lbs without getting lean. A simple bleed valve will work for that. Check your timing, its to easy not to do. If your not sure what it is, then it probably isn't correct.
The fixes are all easy, Check your timing, fuel pressure and add some boost. But don't add boost if you up your timing or lower your FP. Unless your on the dyno again.
WD
