Yeah I understand but I wanted to knw where the piping can be found?? The sch 321 or 304......what ever it is??matafied wrote:i think it was all custom (meet07)
Thanks for the vote of confidenceZenkiCam wrote:chris will kick your a$$.
jk.
Heres my kaboom graph, 35r t4 hot side .68 a/rsil_eightyRPS13 wrote:well i put down 523 at 1.0 bar..nahnah.. but i have to wait a lil longer..lol =( nice response 3200 is that full boost??? anyone have a graph with at .82 GT35R??? im curious to where it hits full boost 4200????
Exactly TRAP speed tells all, I think of dynos just as a tool to properly tune the car, the track is the true performance number.240z4u wrote:Shocker, thanks for the graph. Gives me a better idea of what one should look like. I am still learning the tuning end.
I have come to conclude that dynos are not useful for anything but tuning (which is what they should be good for) and bench racing. Just not enough consistency.
That said, the mustang and dyno dynamics dyno typically read 13% lower then the dynojet counterpart. But thats all in the setup and operator. I am done being concerned about the numbers, but more concerned with making as much power as I can.
Trap speed tells the whole story, unless your a terrible driver like me.
Evan
heres mine... http://members.shaw.ca/sil_eighty/dynosheet.jpgim looking to switch to the 35R .82 and can get her spool a 1000RPM sooner and still have a 600HP potenial....my TD06-25G-16cm hits hard at 5000 dont even need a clutch kick for third gear drifts...lol anyone know if the .82a/r is efficient to those numbers...??? and im looking for T3 four bolt external layout numbers if anyone has some... sorry for the thread hi-jack... but i want my car to be a little more driftable, its more liek a wangan runner right now...Shocker wrote:
BTW 14 psi as well
If you want that get the .63.... it will be very driftable and come on very hard lolsil_eightyRPS13 wrote:heres mine... http://members.shaw.ca/sil_eighty/dynosheet.jpgim looking to switch to the 35R .82 and can get her spool a 1000RPM sooner and still have a 600HP potenial....my TD06-25G-16cm hits hard at 5000 dont even need a clutch kick for third gear drifts...lol anyone know if the .82a/r is efficient to those numbers...??? and im looking for T3 four bolt external layout numbers if anyone has some... sorry for the thread hi-jack... but i want my car to be a little more driftable, its more liek a wangan runner right now...
im running a bosch inline under the hood and a nismo intake on aftermarket 1/4" line...well thats the way the japs had it rigged up... im thinking of doing a nice surge tank setup to make it nice and a lil more fire retardent friendly(2 bosch's perhaps)...lol... what is the maximum power out put with the .63 GT35R 450-500?? .82 480-550??? i want at least 500 out of her, and not hot air either...im sure the .82 would spool fully by 4200 with my setup...and compressionShocker wrote:
your running the inline 044 with an intank pump through the same line right? no issues?
Depends on how much boost, but a guy over here is making a guestimated 550hp at the motor on a Evo I with a .82 GT35R at like 1.8 bar. Pretty good guestimate though.sil_eightyRPS13 wrote: im running a bosch inline under the hood and a nismo intake on aftermarket 1/4" line...well thats the way the japs had it rigged up... im thinking of doing a nice surge tank setup to make it nice and a lil more fire retardent friendly(2 bosch's perhaps)...lol... what is the maximum power out put with the .63 GT35R 450-500?? .82 480-550??? i want at least 500 out of her, and not hot air either...im sure the .82 would spool fully by 4200 with my setup...and compression
I really hate dyno numbers, they all vary. I like trap speeds.Cjmartz2k wrote:
well im getting lots of fuel... 555cc injects are almost maxed out at full boost(98.8%...) to my understanding injectors run better near max. better fuel economy i was told, and more efficient duty cycle. but im sure switching to 740cc wouldn't hurt. fuel pressure is at 60psi,(ha, any higher and we keep blowing o-rings. so we doubled up on imperial ones...nice lil trick) compression is 9.8:1 (roughly), head quench has been removed, running HKS 272 8.5 lift cams,weisco 87.25mm pistons,eagle rods..etc runnnig VPc14 or sunoco equvillant (114octane)if i go .82 will i see full boost at 4000-4200? and peak numbers in 550whp range? i am only running 18psi to get 581whp right now(but hitting hard over 5000rpm is gay unless your on a big track... tq is a lil low in my opinion 423tq... i think a smaller hot would bring the numbers up a lil bit...and yes Fourht gear sweepers are no problem hereShocker wrote:
I've seen charts of people making 620-630 on a 35r .82 on c16, I've seen them only make mid to high 5's too.
I don't doubt you couldn't get an easy 500 with a .63 hotside, gonna need gas of course, even more since your high compression. But that is more than PLENTY for drift. 4th gear sweepers much? lol
