Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Tue Feb 17, 2004 4:22 am
antifreeze is gay.run a 25% antifreeze to 75% water ratio.then run water wetter.my rb doesnt over heat at all, even when we had some nice 65 degree days it stayed right in the middle and the radiator would barely get warm, with no fans.i rigged the stock dohc cooling fan for the condenser to push air through the rad, it works quite well.its set up so that it is turned on by the relay in the fusebox when the car is on and off when the car is off.
