DriftBoy07's Build Thread
Dittoz7
Car: 1997 2f0WtY SE!
Looks Like A Unicorn.
mRodiek
Car: Stock Hatch
^^The second time...what?
Someone help me out here, is my MAF bad? Its the second one Ive been through, could it be the ECU?
mRodiek
Car: Stock Hatch
I know everyone is busy watching tthe Bears kick a** but I need some help if anyone has some advice
JRPS13
Car: 1992 180sx
sounds like mafreset ur ecuunhook one of the cable on your battery an hold down your brake pedal for 20 seconds. that should help
try the voltage on ur tps.......
mRodiek
Car: Stock Hatch
I'll try another MAF, reseting the ECU didn't do it-anyone in the valley with a voltometer?
JRPS13
Car: 1992 180sx
i went through about three mafs and have had to reset my tps several times.....long story short... d detro or n60 maf
mRodiek
Car: Stock Hatch
What difference would the n60 make?
sloweighty
Car: sileighty
DriftBoy07 wrote:So Ive been a busy guy lately with getting ready for the New one out of a 93 Maxima, for $30
can you really use the 93 maxima headlight switch....... ......i never knew that
JDM Sil4ty
Car: Sil4ty
nice build dude .. just get it all together, with no problemos !
mRodiek
Car: Stock Hatch
Yes the headlight switch is damn near identical, mine works
JDM Sil4ty wrote:nice build dude .. just get it all together, with no problemos !
Easier said than done
Im waiting on some parts from Enjuku and apparently Phase2 sent me a package but I havent been home to sign for it so no cigar. The weird part is that I havent ordered anything from them, and I havent given them my new address so Im a little interested to see what it is.
JRPS13
Car: 1992 180sx
well other than the fact that i think i may have maxed out my maf today im assuming you may have tooo and thats probably ur problem. just a guess tho
mRodiek
Car: Stock Hatch
I dont see how I could have maxed it out when all I have is a walboro 255 fuel pump, the turbo isnt much larger either so it isnt flowing more air [even if it was I would be running lean, which Im not].
Ill have to have my dad send me another MAF and see if that makes a difference, even though I doubt it will.
Other ideas are always welcome.
mRodiek
Car: Stock Hatch
Attempting to fix the small problems without money, and nothing but time.
True Life: Im addicted to zip ties Fixed driveshaft bracketSo this is why my wideband doesnt work...Found the PS leak..IN THE RACK, Ill be having it rebuilt when I get $$New cold pipe...Uh....what?And final pic of where she spends most of her time
I dont have a 19mm socket thats 3/8 drive so I have to get one of those to replace my CTS. AND MY STUPID a** MISSED A VACUUM LEAK!! Right beneath the throttle body on that itsy bitsy nipple, I dont have anything to cap it with or superglue so it stays for now..
Bumnah
Car: 1992 240SX, black. Bone stock.
The port at the bottom of the throttle body is not a vacuum port.....
mRodiek
Car: Stock Hatch
On the bottom left? The TINY one? What is it then, I can hear air going in when i push the throttle.
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
It's a vacuum port that only activates when you press the throttle. It's part of the EVAP system intake aka the charcoal can.
White Comet
Car: fc, s13 and mazda6, Sierra
yup and you are correct in thinking you need to cap it
mRodiek
Car: Stock Hatch
Good to know I was right about something. I dont think that would jack up my AFR this much though...would it?
I had an interview @ Pizza hut for a delivery position and when I walk out [I got a 2nd interview wooo!] my car wont start, and after cranking it for a minute SMOKE comes out of my dash near my wiring and the wires are HOT AS s***!
Im wondering if its the solenoid on my rebuilt starter, or if my wiring is shorting out somewhere? I have a Mishimoto starter in my back seat in case my starter is bad, but I dont wanna waste this one too-and Id like to sell it if it is just my wiring.
Jdmstyles
Car: My S13 took a crap on me.
MY PS leaks and I cant trace it. It doesn't leave a spill on the floor. I'm getting tired of refilling it every other week.
tEknoS13
Car: 93' Type X
^ Weird there MUST be a leak somewhere. Get all the way in there and find out.
DriftBoy: damn bro talk about bad luck. Im almost sure you messed up the wiring somewhere.
mRodiek
Car: Stock Hatch
JDMstyles-its probably a seal or the lines arent threaded right...it has to go somewhere though.
Im workin on it Tek, I found 2 wires that have small stripped sections near one another so I wonder if they just touched every once in a while and it wouldnt start or if my solenoid is bad, if she wont start again then Ill swap starters & move on.
I have 2 jobs now, finally wooohoo! Hourly wage FTW! I start one on monday and not sure about the other but I am making progress and hopefully soon enough Ill be able to put $$ in the car. Wish me luck NICO
JRPS13
Car: 1992 180sx
i think sr20 mafs are good to 250hp,im pretty sure that wen my vaccum line popped off my wastegate i made over 250hp as boost isnt regulated, tthank god for fuel cut
StylesCD
DriftBoy07 wrote:JDMstyles-its probably a seal or the lines arent threaded right...it has to go somewhere though.
good luck, i hope you get the money to finish up
mRodiek
Car: Stock Hatch
Replaced my coolant temp sensor and it fixed everything right? WRONG!! No biggie though, it's one more new part i don't have to worry about. Next on my list is the adjustable FPR but it'sgonna take me a couple of weeks til then.
More good news, I have another exhaust leak! Sweet. I think it's between the manifold and elbow which makes me more excited, I am going to attempt to tighten everything down tomorrow morning, maybe I will pull the entire manifold/turbo...maybe not. Pics later
mRodiek
Car: Stock Hatch
Fixed tthe starting problem, found the exhaust leak, the nuts from the manifold->turbo came loose, lost a lock washer so Im fixing it tomorrow..yay no more sounding like a lawnmower.
Onto bigger news....
Bills suck, living by yourself sucks, SRs suck [jk...a lil].
I am looking into trading my SR for a strong KA + cash or a clean a** running coupe. If your in Socal and interested let me know....
Bumnah
Save up your $. Take it to a reliable shop in the area, have them fix all your car problems. Enjoy it.
Better idea than swapping in a KA.
White Comet
mRodiek
Car: Stock Hatch
I have no problems FIXING it if I had extra money, just replacing old parts and tracking down the problem . My skills arent the problem, the money is.
Delivering pizza @ 8mpg doesnt work for me and I need that job because the money is good and its easy. I LOVE my car and my SR, but I need some extra money right now and I cant afford to keep trying different problems here and there when I have bills/rent/gas to pay for now.
PLUS this was supposed to be a DRIFT car, looking back on everything I should have just dropped a KADE and worked on suspension etc. but I didnt, lesson learned
I am not complaining by any means, and I really want to keep my car/motor and finish it entirely but I need to establish a strong foundation here before I can have a fast car. And not even being able to go to meets because I cant afford the gas isnt cutting it for me.
PS I swapped my starter for a new one and she starts everytime
DeeMan
Car: 240sx
wow dis 1 helluva build!!! seems like u still have more work to do til dis thing s drift ready!!
mRodiek
Car: Stock Hatch
zerothread?id=455419
Modified by DriftBoy07 at 1:51 PM 10/10/2009
