Doing KA complete rebuild 250-275HP
strick-
Car: 1990 sohc 240sx
so i just got a 1990 240sx and new to the forums.so i decided to get a new KA motor and completly rebuild it with all new internals. want to try and get anywhere from 250HP to 275HP with OUT a turbo. anyonegot a list of some parts.best cams,pistons and camshaft. might even bore it a little.looking to spend around $2500-$3000.then eventully toss on a turbo after all is said in done.any help would help greatly.. thanks alot
93HATCH240
Car: 1993 NISSAN 240SX HATCH
You will deff. need a bigger budget then 3 grand. Just a decent turbo set up will run a lil less then that. Are you going to be doing any of the work your self of paying sum1 to do it?
strick-
im just going for the internals for around $3000. ill drop it in and see what its got to the wheels and all then might put a turbo on it. havent decided yet. but the work hopefully will be done by me everything but the bore
JeromeS13
Car: 2008 Subaru Impreza STI
I doubt you'll see that much. To get anywhere near that, you'd need to run a pretty high compression ratio. That + turbo = no good.
-Jerome
strick-
what would a mild cam/pistons/crankshaft give me HP wise. no bore or anything
JeromeS13
As I answered in your other thread, basically asking the same question......
I know you're new to the forum and all. But, I do believe you may have read something along the lines of needing to search before you post stuff like this. The search function is your best friend.
zerothread?id=107938
zerothread?id=158354
zerothread?id=9245
zerothread?id=28011
-Jerome
Chukidori
275 hp is impossible on pump gas, without a turbo.
Its impossible, completely unfeasible.
Not with the KA24DE , no way.
With full header back exhaust, High comp pistons, an ECU tune or stand alone fuel management...High duration cams, head porting and polishing, CAI etc
Youd be doing GREAT just to make 200 wheel. N/A builds are not easy ....or cheap .......
Just go Forced Induction, save you alot of headache.
bone_stock_240
Car: 1995 Infiniti Q45
Definately will cost much much more than $3000 to get even 190 rwhp. So far we are looking for the first person to hit 200 rwhp, and can actually prove it with the KA24DE.
If you open your eyes and look down a couple of threads, you will see "Who has got the most powerful NA KA" thread. That is 8 pages long and contains tons and tons of technical discussion. Start there dreamer.
dickie
Car: Killer Turtle
oooh! i hope you didnt go out and buy the car thinking youd get to 275 rwhp on the ka-de without boost. that would suck.
dRiLstar
lol as d!ck said.. but nothing is impossible -Nike!
strick-
i guess ill shot for around 275-300 with turbo then. but thanks for all the help
bone_stock_240
Yeah, that is a really good goal to aim for turbocharged. Decent power, but nothing crazy.
dickie
Car: Killer Turtle
thats about what i would want in a daily for an s-chassis.
BadMojo
Car: 2007 Mazdaspeed 3
dRiLstar wrote:lol as d!ck said.. but nothing is impossible -Nike!
You can try a setup like this...
Just go to Autozone and ask for Jato. Accept no substitutes! :D
Morph
Car: 91 Sr Powered Coupe
Well on the OP's budget it is.
The race s14 that has been floating around the net had 285 i wanna say and that was a race built motor. Sorry kid unless you have unliminted cash flow, alot of spray, or a turbo you are not even going to come close to your previously stated goals.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
It's cheaper than you think. This is quoted from Mike who answered all of our questions with the GT3 parts list. He even has some parts for sale.
mikegt3 wrote:Hey guys, I've been off this site for a while. I started reading this post from the beginning but when I got to the pissing match somewhere in the middle pages, I jumped to page 7. My 240SX GT3 racecar is sold and I have some spare KA 3 valve parts I'm looking to sell. If your interested, email me directly at [email protected] Nissan comp intake manifold ( ported for 44mm Mikuni's) $750 Dump that CRAP injection! 2 Mikuni 44mm stage 3 race prepped carbs $1,5004 Carillo rods (Brand NEW!) $6001 Rebello cam (used but good) $3001 set of Nissan comp valve springs (used but check good) $1001 Nissan comp head gasket $752 Nissan comp pan gaskets $50 for bothBuy the whole package for $3,000 !
With some 12 to 1 pistons and some flow work on your cylinder head and you WILL have a 200RWP KA !
BTW If you guys are going through the expense of having KA cranks custom made,.... Make sure you have the balancer bolt threads machined all the way to the first main journal. That's a mod we do for the 280hp race engines. If you don't, the cranks break off just behind the balancer. The extra long balancer bolt "holds" the crank snout to the rest of the crank and they don't break there any more. Remember,....We run these KA's at 7,500 rpm's all day long!
Thanks, Mike
mikegt3 wrote:
It will be with a Nissan twin cam KA and TWM injection,Pink cylinder head,Rebello cams,carillo's,J&E's, ATI balancer, stock crank (drilled snout), MY hand made header and exhaust(4-2-1). Mike
BTW if you guy's think that you need alot of parts to build up the KA you are crazy. It's all in the method used to modify the crank shaft for higher RPM use.
