I'm assuming the video bypass is working? If so, that should function as an acceptable grounding point. I would also recommend tapping into the red accessory power wire for power to the adapter. If you use one of the always on power cables, you may be draining your battery with the PAC connector (albeit very slowly).domdada wrote:That's the diagram I was goin by. At first I did try hooking up the power to the harness, and I got nothing....so that's when I tapped it in to the power outlet. I didn't check the continuity with a multimeter and this is probably because I don't have one...lol. I'm gonna try to run the ground wire to where I grounded the green parking wire to bypass watching dvd's while driving.
Domdada, I may go out and install my PAC unit just to help you out with this... I would have to really dissect where you made the mistake, and right now I'm a bit busy... thanks for holding it down applebonker, I'll try to chime in with some useful info after I re-read through this later this evening and have some free timedomdada wrote:I'm sorry, I meant to say the 3rd pin on the bottom (the first wire available on the bottom) and the 4th pin on the bottom for ground (the second wire available on the bottom)
Not sure what packages you have on your car, but if you have factory bluetooth connectivity (I think I'm seeing a sunroof so you should have this) the module is factory installed in the trunk under the styrofoam. Hopefully this wasn't removed. If it was, the steering wheel controls will not function.domdada wrote:AppleBonker....Bluetooth to the trunk? I didn't run anything to the trunk. The only thing that I know of that would be ran to the trunk would be the wire going to the reverse light for a reverse camera, but I didn't do that.
Thanks Doc, i know about being busy. I'm juggling 3 jobs right now so time is at a minimal to me as well. I thought that you had the PAC in there and would have an idea what the problem would be. Take your time, I'm really in no rush to get it working. The remote control has been handy and if I don't get this to work.....I may just take the PAC out and not bother with it.
well, remember, your parking brake wire is grounded somewhere right? So I just connected the ground on the PAC-SWi JACK to the grounded parking brake wire. Also, yes, just connect the power on the PAC-SWi Jack to the power on the aftermarket harness adapter (or the kenwood's power)domdada wrote:Robert,
Where did you ground the ground wires to? And did you connect the power wire to the kenwood's power wire or to another power source?
-Domonic
not exactly, if you can play a movie through your DNX while driving, then you have correctly grounded the parking brake, and can tap into that grounded wire! The DNX , although it uses the same drive for DVD's/ CD's, can tell the difference between the two, and will allow CD's to play regardless of the condition of the parking brake, but will eiether black out the screen or have a flashing parking brake sign (while driving and watching a movie), if the parking brake isn't properly groundeddomdada wrote:zerothread?id=294580
Looking at the link above....there's a pic that shows where the parking brake line was grounded to. I grounded mine to the bolt directly below that. Now seeing that when I put a CD in the DNX, it plays through the DVD source....and if this is working, does that mean that I bypassed the parking brake wire and have a good ground?
Ok cool, hopefully you have a soldering iron, I just picked up a cheap one from radio shack to do mine...domdada wrote:I'm about to leave the house to go to work....I'm gonna grab a dvd with me and see what happens. Like I said, I believe I should have a good ground because it's using the bolt below where you put your ground wire in that pic but it's on the same metal bracket.
I started out not knowing how to do any of this stuff.. an one by one, I began to tackle projects, learning as I go... after you tackle this yourself, and see how easy it is, you'll thank me! It'll give you that much more confidence to go tackle the next projectdomdada wrote:******EDIT******
I got DVD playing so that means my ground is good. I'm gonna ground the PAC to that spot too and at the same time, sodder the resistors and hopefully I will be all set. ------------------------------------------------------------------------------------------------
lol....Thanks Robert.
One of the installer (who i'm friends with) who used to work for my friends car shop still does car installs at home, but he's so busy....it be weeks till he got to my car. Also, because of the relation we have, he'll try to charge me next to nothing and I really don't want him to do that, he's got a family to raise.
But on a serious note....I really do appreciate ur help with this.
Modified by domdada at 10:23 AM 7/25/2008
well I went over this with my custom audio guy, and he also stated that he feels the new Boston Pro 60's are lacking in the mid bass arena. For $500, I am definately disappointed. RIt could be that I'm just putting too much power to them... the Rockford T600-4 does about 200 watts @ 2 ohms and ~120 watts at 4 ohms... the Pro 60's are 3 ohms, so I'm putting around 160 watts to them.domdada wrote:OK Doc, I have another question. First, I haven't had time to go back behind the radio and fix up the PAC but I hopefully will soon. My question for you is this.
I saw a post regarding the Boston Acoustic Pro60's and that you are not happy with the way they sound. I was thinking about getting these for my interiors except I was going to get the Pro 60's for the rear deck and make a templet for them to fit there. I have an audio control 3.1 and audio control matrix from my last car that I can tie into it the system. Will this help the cause for making the speakers sound better or are these speakers just a waste of money? If so, what's the next best thing?
OK, for crisp highs, the Pro 60's will hang with anything out there in the market... I have ~ 160 watts going to these things and the highs don't distort at all at cranked up volumes... ( aguy pulled up next to me last night while I was parked at a red light, and tried to out blast me with his system... after I cranked my up, it COMPLETELy drowned out his system, and he had to close his windows.... LOLdomdada wrote:ok, I see what you are saying. Everyone here in the Detroit area know that the baddest interiors to get are Boston Acoustics and MB Quartz....(some people swear by pioneer and the "REV" series interior, which I had in my '03, but aren't all that). I researched and did a comparision on the 2 and seen that the B/A's specs are more appealing than the MBQ's.
Regardless of the interior speakers I choose to go with, I wouldn't really push them to get too much Mid-Bass Out of them. I would want them to sound more crisp and clean and have my sub do all the banging (Just like a home theater set up where your surround speakers give you the nice, crisp sounds of the music, and the subwoofer adding the bang.) But that's just my opinion.
You said that there is too much power from your amp to the speakers and this is resulting in the not so great sound.....I have 2 Mmats SQ 4070 amps that I'm gonna use to hook up the interiors. I was going to get 2 sets of the Boston Pro60 and a set or 2 of the S35 Tweeters. Will these amps do for the speakers.....are they overkill or not enough???
Do you really have your sub crossed at 120Hz?!?rjdmmfl1 wrote:
Again, my only complaint with the Pro 60's is regarding the midbass... but to fix that, I'm gonna keep the front crossover @ 120 HZ
Ok, now I'm really confused. Are you planning on putting the Pro 60's in the front doors and the S35's in the factory tweeter location? That would be complete overkill. There is no way that many drivers will sound good together. You will get all sorts of frequency cancellation among other things. More speakers does not equal better sound. High quality setups operate under the blanket idea of less is more. Less drivers means less of a chance for physics to come into play and distort the imaging of your soundstage. I've only seen a few very top notch audio setups that have consisted of multiple drivers for one location (IE front right) at the same frequency, and they were all home theater setups costing upwards of $3 mil. To do this correctly in your car (which I've never seen BTW - look at audio quality competition rigs and there will not be any setup such as you are suggesting), you would need to do the most incredible job tuning. In fact, there are probably less than 10 people in the US that could tune this correctly, and they would charge you far more money than your budget allows (judging by the speaker selection).domdada wrote: -B/A Pro60 for the front and rear -B/A S35 Tweeters for the Front -Maybe another S35 Tweeter incorporated in the car somewhere. (The SPZ were only mentioned cause DOC was tellling me about the FOCAL UTOPIAS and I said that woundn't the SPZ's be a better way to go)
As to power for these speakers, I had 2 Mmats SQ4070 amps but Doc said that they will not run at the ohms that these speakers need to be at so I'm gonna sell them and opt for the Rockford t-400-4 amps.
Now to better tune these speakers and the sub (Mmats Juggernaut 12" w/Mmats 2200.1 amp) I have an Audio Control 3.1 sound processor, (http://mobileaudiocontrol.com/...0&l2=) which I had in my last car and was running 2 15" Juggernauts and 4 Pioneer Component sets, and I also have the Audio Control Matrix Line Driver for an extra boost http://mobileaudiocontrol.com/...9&l2=
What do you think of all this? DOC....Give me you input as well.
