It didn't do much to the slush because you've got the weight on the wrong end. You need the weight concentrated on the bow, otherwise it'll just climb up on top of the snow. As long as the point has weight, the trailing edges will be fine. Move the cinder blocks to the bow. Stack them on top of each other and concentrate the weight right on the point. Or find a better weight source. Like lead. Or mercury.naladude911 wrote:So I tried the plow today. I pulled it around and everything seemed fine. The design held up but it doesnt like slush. It didnt do much to the slush. We are supposed to get a lot of snow Thursday so I will try again.
A Trailblazer? Yeah, that'd probably help. 4.2 Vortec FTW.ZOMG.SR20 wrote:you could have just bought this
Ah, so you're coming out of the closet too?PoorManQ45 wrote:The tail lights are fine. They're better then blacked out stockers....
LOL
Suburban driveways often use soft blacktop with a tar-like sealant on top (a BAD place to set a jack stand). He might put some ugly dings and marks in it, but it won't be ruined.numbnuts240 wrote:asphalt is a lot more forgiving than concrete. when the plows do their final runs, there are sparks flying around, and there's a lot more downward force going on there than he's go with that thing. his few passes with that setup, even with the weight at the point, isn't going to do much to harm his driveway.
This man, this liker of turtles, speaks the truth. I was changing the brakes on my friends Civic as it was sinking into the ground...Jesda wrote:
Wow, if this is a real catback there may be hope for Nala!!!naladude911 wrote:custom magnaflow exhaust. magnaflow muffler, resonator delete. Sounds really deep like my dad's tahoe.
I know, but why did you pick the largest tip you could find? That's barely acceptable on a 6.7L Cummins diesel let alone a 3.5L QX4.naladude911 wrote:custom magnaflow exhaust. magnaflow muffler, resonator delete. Sounds really deep like my dad's tahoe.
If he moves the hooks lower with the same size chain he will increase the angle from the ground and it will get pulled up even more.TJG wrote:you should pull the plow from lower, it looks like the eye hooks that the chain attached too are on top. because your hitch will always be higher than the plow, the chain will be pulling at an upward angle probably trying to lift the front and allowing some snow/slush under the nose of your plow defeating the whole purpose.
Even after the thread about your homework assignment on tension in cables you STILL don't get it?In reality it IS. If there is tension in the chain, it is pulling along the chain. Just like in your homework their is a force on the car, and a force on the plow, both pulling away from the objects in the direction of the chain.naladude911 wrote:Your theory may seem right, but in reality its not. i checked the plow and its not getting pulled up.
he should be getting plenty of snow this weekend.Ajax wrote:Though I'm looking forward to the next NE snowstorm so I can see the aftermath pics.
