DIY snow plow
naladude911
Car: 2001 Infiniti QX4
so your saying add another eye hook to each end and have two more chains?
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
The QX4 is not meant to be used as a work truck, it's sole purpose is to cart you and your family from the house to mall with an upgraded level of luxury not find in it's Pathfinder sibling. It's not designed to go off road (it's 4x4 system is rudimentary at best), it's not meant to be a work horse, and it sure as s*** isn't designed for the stresses of plowing. The chassis and the power-train weren't designed with the thought that someone would use it plow snow or undergo severely heavy labor.
Snow is heavy, very heavy, and the concept of moving it from one location to another is an incredibly demanding job (hence the reason doctors say to take it easy when shoveling). The reason that most plows are made out of lexan and/or plate steel is because they are 2 of the most durable and strongest materials that can be used. Wood does not have the strength to push, pull, cut, or chop it's way through lbs, or tons of snow and ice.
Having said that, plows designed and built for light duty trucks (1/2 to or below) are made with lexan with steel reinforcement bars, and all plows utilize hydraulics so that you can push the snow off in a variety of directions. You simply can't just plow snow straight unless you utilize a reversed V style plow, this way the snow is split in half and pushed off to both sides. if you try to plow even 6+ inches of snow straight the weight of it will bog you down and create a wall that will essentially grind you to a halt.
I think the standard unit of measure for snowfall is 1:3 (meaning 1 inch of rain = 3 inches of snow) now that alone might not meaning anything but take a measurement of 1 square foot, and put an inch of water in that square and weigh it, now multiply that by the entire space that you want to plow. There's a reason why most of the vehicles you see out plowing are 3/4 ton and above, and most if not all have H.O. V8's or diesel engines and all of them have extremely rugged 4x4 systems. Not saying you can't use a light duty truck or SUV to plow, but they generally are using purpose built plows designed and made for those specific vehicles.
/RANT
Seriously though, I understand you want to make your own plow, go for it, just do a s***-ton of research before you go out and waste money. I'm willing to guess that you have roughly $75-125 worth of materials that you've used there, as 2 2x6's are roughly $12-20 a plank, the chain is about $3-5 a foot and the angle iron and metal supports you have there aren't cheap either, throw in all the hardware you have holding it all together + sales tax and you sir have wasted a decent chunk of someone's paycheck. Way to go, you are a dumbass.
Modified by Chaotic_Warlord at 11:36 AM 2/20/2010
Bubba1
Car: 2003 Nissan 350z
2024 Honda HR-V
2008 Toyota Corolla S
2001 Toyota Avalon XLS
Red coupe wrote:Yes, but you don't have a massive 4wd truck with snow tires...
So now, to plow an area you have to first be able to drive through it... In which case you could have just driven through it in the first place.
Did you happen to notice how massive the attachment is to that truck?? If you're using an ordinary tow hitch to mount it, and attempt to pull more than an an inch or two of snow?... wait, nevermind, go ahead and do it. We're in for some major laughs when you damage your SUV....
naladude911
Im only plowing my driveway, and we get 3 inches max usually. If we get more then I will plow in between the storm.
naladude911
Bubba1 wrote:
Did you happen to notice how massive the attachment is to that truck?? If you're using an ordinary tow hitch to mount it, and attempt to pull more than an an inch or two of snow?... wait, nevermind, go ahead and do it. We're in for some major laughs.
Why cant I use the trailer hitch
Chaotic_Warlord
here I'll make it easy for you
http://www.lmgtfy.com/?q=snow+plow+design
Edit: study this...
Bubba1
2024 Honda HR-V
You can but it's not designed for that kind of abuse. The towing capacity is set low on a QX4 which means the frame cannot withstand much stress. Keep in mind, a 3-5000 lb towing capacity assumes pullng something sitting on wheels, You're dragging a blade that fills with accumulating snow/ice (potentially very heavy). You'll exceed the maximum capacity very quickly if you pull too much/too far. Plus it just takes a small obstruction like a stubborn patch of ice while dragging that thing, to risk bending your vehicle's frame. that is, if your contraption doesn't give out at a safe preset point below that capacity.
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
Bubba1 wrote:. that is, if your contraption doesn't give out at a safe preset point below that capacity.
It wouldn't be a "preset" or predetermined point but, given what I've seen so far, it will probably give out before the chassis. Well before the chassis.
Edit: And this.
Modified by Veriest1 at 12:25 PM 2/20/2010
Bubba1
2024 Honda HR-V
We'll soon find out.
sbird1
Car: 2006 BMW 325i
1,000,000,000,000 times cooler than any snow plow you ever build:
http://www.youtube.com/watch?v=1w1CO6MYt8k
Veriest1
Car: '96 BMW M3
I guess so....
naladude911
Yes were getting a lot of snow this week. I bought two more 2x6's (they're $5 each believe it or not) to brace the V. My dad is helping me now. Finishing it up tomorrow.
Razi
Car: Moo
At least you're trying.Good luck with it Nala.
naladude911
thank you. Hey, its a lot better than the first one lol
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
naladude911
Here are the final pictures.
ZOMG.SR20
Car: 1990 s13
you could have just bought this
naladude911
give me $3000?
ZOMG.SR20
Car: 1990 s13
with the truck its 5k
naladude911
It will work similar to but better thanhttp://www.youtube.com/watch?v=30kY3dmR3ms
Ajax
Car: 1991 240sx SE
2010 Mazda 5
So, how big is this driveway? I'm wondering how you're actually going to clear the snow once you create a single plowed stipe down the driveway (assuming the eyebolts don't rip out of the lumber).I'm imagining that if successful, you will have created two long piles on either side of the plow. Then you will have to drive just shy of center so that your plow does not push snow right back over where you just plowed (because of 90*angle in center of plow). That's assuming your vehicle can handle pushing twice the snow on one side of the plow with one side treading driveway, the other snow on driveway, with hopeful ground clearance over the long pile of snow.This is probably a statement mentioned before, but I don't think you thought this through.
PoorManQ45
naladude911 wrote:It will work similar to but better thanhttp://www.youtube.com/watch?v=30kY3dmR3ms
The snow in that video is the fluffy kind. I hope you don't get any wet heavy snow
ThatGuyRoger
Car: 08 Super Black Altima Coupe 2.5S
wouldnt this be easier?
naladude911
So I tried the plow today. I pulled it around and everything seemed fine. The design held up but it doesnt like slush. It didnt do much to the slush. We are supposed to get a lot of snow Thursday so I will try again.
Razi
Car: Moo
Change your taillights!
big_rig
Car: '09 nissan altima coupe 2.5s '88 bmw E30 '93 zj jeep
naladude911 wrote:So I tried the plow today. I pulled it around and everything seemed fine. The design held up but it doesnt like slush. It didnt do much to the slush. We are supposed to get a lot of snow Thursday so I will try again.
question...
when the snow builds up and you need to use the snow plow get your vehicle out of the driveway, how is pulling the snow plow going to help? i thought the whole function of a snow plow was to clear a path. this looks more like a failed street sweeper to me haha
Ajax
Car: 1991 240sx SE
2010 Mazda 5
naladude911 wrote:
So the slush gets left behind. Honestly that's the worst part about shoveling because its the heaviest. And now you've packed some of it down. I recommend shoveling that stuff before it solidifies overnight.
sbird1
Car: 2006 BMW 325i
Nala, those tails are awful. Please give those back to eBay and exchange them for some stock ones again. Please.
krash
dude please change those tails......
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
you should pull the plow from lower, it looks like the eye hooks that the chain attached too are on top. because your hitch will always be higher than the plow, the chain will be pulling at an upward angle probably trying to lift the front and allowing some snow/slush under the nose of your plow defeating the whole purpose.
