DIY snow plow
big_rig
Car: '09 nissan altima coupe 2.5s '88 bmw E30 '93 zj jeep
this thread made my day. i bet nala kid and i would get along real well...seeing as how we are both ruhtards haha
PEZi
yes... you guys should get marriaged'd
naladude911
Car: 2001 Infiniti QX4
were expecting 6-18 inches this friday. Im going to rebuilt my plow but connect it to the tow hooks using S hooks.
car nut
Car: GT500.
naladude911 wrote:were expecting 6-18 inches this friday.
That's not a ridiculous range or anything...
That much snow will destroy your plow.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Video this time. With commentary.
gmac708
Car: :o)
1970 Datsun 240Z
1972 Datsun 510
You know if you tied a bunch of leaf blowers on the front bumper...
naladude911
So I went to home depot today and talked with a couple of workers there and designed a rear plow. The plow will drag behind the car in a V formation, attached via chain to the trailer hitch. There will be two 2x6's attached together on each side of the V, along with a metal blade along the bottom,
Zydeco
Car: The poster formerly know as -]sTm[-HeavyHips
naladude911 wrote:So I went to home depot today and talked with a couple of workers there and designed a rear plow. The plow will drag behind the car in a V formation, attached via chain to the trailer hitch. There will be two 2x6's attached together on each side of the V, along with a metal blade along the bottom,
can we get some MS paint blue prints plz.
bluepillow
Car: 05 elantra
LMAO Home Depot employees are trained to feed you bulls*** as long as you keep piling your shopping cart with merchandise. Only a small percentage of the workers have a clue as to what home improvement is.
<-- former Home Depot associate
But I agree with -]sTm[-HeavyHips, give us a pic.
naladude911
As requested here is a pic of one side. It weighs at least 50 lbs with the block on it. I will have two of these in a V formation.First of all my workshop :0Each piece of 2x6 is bolted together using 6 bolts (bolt heads are on the other side).
PoorManQ45
Why would you do a pull behind design?
That means you have to drive through the snow to plow it.
Zydeco
PoorManQ45 wrote:Why would you do a pull behind design?
hes going to plow the schools parking lot, so it want close when it snow.
naladude911
Red coupe
Car: 92 Nissan 240sx Coupe
Yes, but you don't have a massive 4wd truck with snow tires...
So now, to plow an area you have to first be able to drive through it... In which case you could have just driven through it in the first place.
naladude911
I drove the Qx4 in over 2 feet of snow and it never got stuck. That was up a hill btw. My driveway is a huge hill so I will drive up from the bottom, incase the plow goes under my rear wheels. I finished it btw, I just need to brace it. It weighs around 100 pounds and is strong as f***.
naladude911
Chaotic_Warlord
Car: Black 5 speed Swapped 1995 240sx
I just want to throw this out there since apparently no one else has...
Nala you are aware that you are by chance ruining any chance of a successful life right, I mean most major employers and even a lot of major colleges do a full background on you, why do you think the news keeps telling everyone to watch what they post on social websites or the internet in general? It's not for the hell of it, it's to inform you as a future student and/or employee about what you say and/or do has a habit of following you more now than it ever has in the past.
Edit:Google yourself, you have said a ton of stupid crap on Facebook... I take that back, Everyone google Stephen Sett (can't be mad, you're name is in your public profile on here.)
Modified by Chaotic_Warlord at 11:34 PM 2/19/2010
naladude911
I just made a snow plow.......
Razi
Car: Moo
[quote="Nala's response to a Facebook group named "Apple Will Rule The World""] dean go away, you are probably thinking of the apple fruit will rule the world. Go AWAY[/quote]
naladude911
This plow has so much win....it weighs over 100 pounds, has steel plating, and is reinforced just like NICO TOLD ME TO.
Red coupe
naladude911 wrote:This plow has so much win....it weighs over 100 pounds, has steel plating, and is reinforced just like NICO TOLD ME TO.
Learn how to use a miter box.
naladude911
I have one. Home depot cut the wood.
Red coupe
naladude911 wrote:I have one. Home depot cut the wood.
I didn't say get one, I said learn to use it.It will surprisingly still work on wood, even if home depo cuts it first.
naladude911
. Il use it for when I brace it tomorrow. Good night.
krash
Its going to break. Again. Make the angle between the two pieces of wood bigger, and brace the ends, probably with chains that mount to the hitch. By mounting the hooks on top of the plow with chains instead of a fixed rod, when under stress, the plow is going to try to tilt forward, but it cant because of the shape. This is going to stress the ends up the plow. This, combined with the sharp angle you have used that will trap snow instead of push it away, and the cinder blocks that you have mounted on the end, will break your plow. Remember, this is not steel, this is wood. Its going to want to bend.
And it looks like you can only plow about 4 inches of snow with that.
ALWAYS sketch something before you go out and make it. It will save you time, money and resources. So when you sketch something and post it on nico, we can all tell you it will fail from the get go BEFORE you go out and waste money.
PoorManQ45
For the joint between the two pieces I would use a piece of 3" angle iron.
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
Every dozer, bucket, plow, etc. that I've ever seen that was intended to move dirt, snow, or babies around always seemed to have more frontal area than your 2x6 plow does.
Chaotic_Warlord
Ok, apparently no one is getting through to our resident space cadet, if you f*** up your vehicle because you didn't listen to anyone I don't want to see a "wah I broked my vehicle trying to snowplow" thread, I will flame you mercilessly and may even be forced to drive up to your town to kick the crap out of you for being stupid. For the money you are wasting on on trying to build a snow-plow you could have bought a used one for cheap or hired Handy Manny to come and plow your driveway.
If you are really intent on doing it yourself go buy one for an ATV (I'm sure your spoiled a** has one of those in your driveway), they are 1/4 of the price of a full size plow, and get the job done just as well, and in fact are more suited to driveways and sidewalks.
These plows that you see that you drag behind aren't intended for snow, they are actually intended to level off dirt for paving, masonry, and sports field purposes. I guarantee that if you use that thing that you built on anything more than 2" of snow it won't work, and with 2" off snow even I can drive through that with my 240 and it's bald a** back tires.
naladude911
1. How would it hurt the QX4?2. I am fixing that gab3. I didnt show the other side, there are two angle braces, and 6 bolts on each wing. 4. I am bracing it even further.
krash
it would hurt the qx4 by you sliding on snow into a jeep liberty. you need hook attachments on the end because by pulling from the center, you are over stressing the ends of the "plow" and since its a chain, its going to want to tilt. Adding mounting points to the end points will lessen this effect.
W/e you're not going to listen. Have fun breaking things and crashing.
