Ha Toronto is broke! We just found out that our province is cutting $150 mill in funding next year so we're going be driving on gravel soon lol. I may have to jack my car up and get some MT tires to survive.06M4.5 wrote:The problems are the streets, they need to start fixing them
- be sure to use caution in the Norfolk & Portsmouth areas. They have the roughest roads in the area. IMO..mexillis wrote:I'm in sova now so I might make it softer since the roads are nicer and have a smoother/floating ride.
Haven't decided quite yet. I wish d2 made the piggy back shock system for our cars. I think the rally or drift versions might have more adjustability.White-Rush wrote:- be sure to use caution in the Norfolk & Portsmouth areas. They have the roughest roads in the area. IMO..mexillis wrote:I'm in sova now so I might make it softer since the roads are nicer and have a smoother/floating ride.
- MSVARA, if you had to do it again, would you still go with coil's, instead of springs?
Agree, however just to clarify my shocks had 160k kms. I know they weren't as good as new and the mounts were noisy. I know for a fact that better coilovers exist just not for the M's. When I say better I mean coilovers that have the ability to adjust more than just linear compression/rebound. An example would be TEIN Super Racing with 16 way adjustable compression and rebound independently adjustable. Yes they are over $2K but our cars are worth it.06M4.5 wrote:...And please don't fool yourself and think that your oem suspension is still good after 65k miles, your just driving on springs. Going from dead struts to any new coilover system will be night & day. So far all the M's that I have lowered needed the oem struts replace before 60k miles. I have seen M45 sport struts go bad at 30k miles. It's funny when I hear others state that at 90k miles they still don't need new struts, it rides perfect.
finikM35 wrote:Here is my alignment 2 weeks after install.
I might need camber arms $180 plus $150 installbolts were frozen it was best they could do.
Partysan, I'm going back to Jersey to visit my hometown. PM me pricing and let me know if you can get Eibach Pro kits for M45 at a good price. I might end up picking it up when I go at the end of this month.Partysan7 wrote:Ok so I pulled the trigger on the D2s today should be getting them in few days. Also anybody in the Tristate needs a set let me know I can get a hook up for a price not found anywhere else!!!
you need to get the nut that holds the bottom of rear strut, 2 of them. The oem nut is welded to the oem strut. It doesn't come in the D2 kit.Partysan7 wrote:Just got them today, looks good and made of high quality.everything is included even bracket for brake lines..(someone said it wasnt included) anyways I will be most definetly installing them next Saturday by a shop. What are the settings (dampning) that you fellow M35ers are happy with ? I live in central nj so the roads are very slightly better than NYC. Any suggestions and tips are greatly appreciated.
it would be best to extend the tool so that it sits on top of the rear deck. The hole should should be a little bigger than the size of the toolPartysan7 wrote:Thanks Freddie and Finik.
I got the nuts yesterday at the dealer they were $2 each I took 6 of them .The dealer didnt rip me off on that I guess![]()
Finik--> what settings are on your rear ? The front I can adjust to my liking.
Btw will be working with the shop to see if something can be done to adjust dampning on rear ( maybe drilling or cutting from trunk) to get access.
