Here is my HowTo: howto-install-a-suspension-t572911.html#p6458255pedsemdoc wrote:msvara
you're doing this yourself, right?
I know Ilya recently did a DIY for BC coilovers--not sure if you're using his DIY to guide your install
Plus, are you going at alone or are you enlisting/bribing/begging for another set of hands?
could you please take some pics or at least comment on the differences when you tackle this (little) project for these?
I'm a little hesitant about trying this, but it doesn't look too difficult--just time consuming.
I just want to get a better idea of what I might be getting myself into if I try this.
msvara wrote:Awesome. Thanks for all the tips. Yes I will be doing this completely alone. I have an electric impact drill which should help with the initial loosening but should I need to break I also have a 2' breaker bar with 1/2" drive. Where did you guys jack the front from underneath? I don't want the sway bar to interfere so have to jack the front/rear up together.
I have a lift so I use the rocker panel or what not.
When doing the front couldn't you just remove the bolt at the top of the yolk and the three in the engine bay to remove the front strut/spring? I'ld rather not remove the two bottom bolts if I don't have to.
Yes, but I tried that and didn't have enough movement to get the bottom of the strut out of the brace/yolk. If you can figure out how to do it, we can update the HowTo document. That was my initial idea too.
I've set the preload on the springs by loosening the lock collar then lower spring perch then hand tightening the lower perch and using the provided tool one full turn after contact. Then fully tighten the lock collar using both provided tools at once. This is just to have it ready to install. I have a drift and hammer for final tightening.
Good.
I'm actually glad the rears are full coilovers because the kit where they are separate looks difficult to adjust height.
Yes, I had to call Freddy when doing my BC's and he helped me out but it was taking forever so I got frustrated and paid a local shop $100 to get all four corners adjusted to where I wanted them.![]()
I will take photos using my phone and do a complete write up for all who are interested. These ran me a bit over 1k with ups shipping from JM auto racing. This place was recommended by Jim at D2 America.
I believe most places (at least BC does this) send you a new strut/shock and charge you for it until you return the bad one. So technically, there isn't much downtime. I wouldn't have bought coilovers if that wasn't the case.msvara wrote:Don you have a few more options out there with an M45. If you have a bit of disposable income then do it. I am putting money away now for either another set or the OEM just in case if these coils fail after a year or so. The warranty is only for 1 year on these btw.
What did they do to save you $200, I am in canada and I am interested!msvara wrote:Full Gas tank (Check). Thanks for that as well!
I have multipoint sockets as my standard sockets then 6 point hardened steel (similar to these http://www.globalindustrial.ca/p/tools/ ... Mgody2QAdw) for my impact drill. I did some other work a while ago and using the multipoint with the impact drill rounded the bolts nicely and quicklyThey're okay for lighter wrenching but I agree 6 point for the tight stuff!
$980 is a steal for sure, but JM Auto Racing did something else which saved me over $200 shipping them to Canada.
Worth a shot. You have to get quite the leverage on it...as the normal sitting position of the steering assembly is 'up'. It won't drop down enough...so get ready to maybe have another person push down. I would leave the top nuts on until you have it out of the wishbone otherwise it will fall and may injure you lol.msvara wrote:Thought I would update the thread with a bit more info I read up on. A few guys attempted to remove the front strut assembly with the wishbone still on the car and they were successful by following these steps.
PB blaster everything (Wait min 30 min).
Remove wishbone to strut bolt completely.
Remove sway bar bolt and disconnect.
Using a large screw driver or pry bar, pry the space where the strut to wishbone bolt was installed apart while tapping the wishbone with a rubber mallet. This should allow the wheel assembly to drop out of the strut.
Then remove the upper mounting bolts and remove the strut.
Will give that a go and see if it works out.
I just removed the end link nut and disengaged that, then undid the wishbone and moved the whole arm (pushed down on the rotor). This allowed me to get the wishbone out and the necessary space.msvara wrote:Ahh steering linkages, forgot about them 8) Can I not just unbolt that as well? I guess by the time I go through all this alternative trouble it may have been easier to just remove the wishbone as well hahaha.
