For starters, thank you VERY MUCH for the fast feedback, we all appreciate it!!!
AceInhole wrote:Install:On installation, we realized the pistons dont extend long enough to mount the coilovers while in the stock relaxed position. Once we extended the lower mounts out as far as possible, we just pre-compressed the lower arms with a jack to meet the lower shock mounts. On my S14, the fronts then sat waaay too high, so we redid it and virtually compressed the suspension to ride height levels. With it like that, it settled at about what my sportlines sat at.
This might be an issue or it may not be one.
Usually, shock manufacturers try to design their shock/shaft lengths so that they work from minimum desired travel (where it hits the bump stop) up to full droop. Of course, with shortened shocks/struts and lowered cars this may not be possible so it is up to the manufacturer to ensure that the shocks/struts are designed so they can limit the droop without being damaged from the repeated "toping" (as opposed to bottoming) of the shaft. KONI even states so in their documentation (.."...all Koni dampers are designed to withstand the loads of limiting suspension droop etc., etc.").
So, assuming the D2 coilovers also take care of the limited droop, the real question would be how much available travel they have. I took the liberty of "annotating" one of your pictures for "measurement purposes".
The green lines on top of the springs are of equal length. All springs appear to be roughly of the same length. Tthe only exception is the top coilover where the spring appears much shorter but this is a photo-aberration, the shock body also appears to be shorter than the bottom one so I assume we should discount it. This would mean that all the springs are of the same length and all close to 7". I do not think that D2 would intentionally preload the springs on the coilovers any more than necessary for them to be seated properly. However, you stated that the harder springs were longer (???). I cannot really see why they would do such a thing (as in my previous post, common sense would indicate that softer springs wouild need to longer to ensure an even ride height everything else being equal).
So, visual clues and assumptions indicate that the shock/strut design puts a limit to the maximum travel available and it is 7". Now, can you give us an indication of the size of the bump-stops?
Furthermore, we can infer available travel from general information regarding springs. Assuming that indeed the springs are not preloaded on the coilovers any more than for proper seating, and assuming again 9Kg/mm fronts (this is 503 lb/inch), 2640 lbs for the S14 and a 50/50 wieght distribution (maybe off but I do not know the real one) we get 1320/2=660 lbs on each front wheel. Your spring would compress by 1.3" leaving 5.7 inches of travel remaining.
Now, I do not know what the exact specs of the 9Kg/mm D2 spring are but I will use the equivalent one from Eibach (ERS): this would be the 0700.250.0500 meaning 7 inches long, 2.5 inches ID, 500 lb/inch. In their catalog they say that it has a spring travel of 4.06 inches before coilbinding (their coilbinded -block- spring length is 2.94 inches so if you subtract this from the 7" free length you get to 4.06).
Subtracting the already used-up 1.3 inches (from the static car laod) we are left with 4.06-1.3= 2.76 inches of available travel before coilbinding.
Now, I may be off in the weights/distribution, etc. but not by much. Since the coilovers are already mounted we have no way of getting measurement now so this is just food-for-thought!!! Be carefull though with raising the lower spring perches!!! It may lead to coilbinding problems that I actually have faced in the past with seriously detrimental results in the performance of the suspension.
problem Example in the rear section below.
Quote » The rears, on the other hand, dumped with the lower mounts fully extended. I haven't checked to see if the springs were seated to begin with though, so I can still raise the rear by raising the spring collars.[/quote]I assume you mean here that with the lower mount fully extended the rears were still much lower than "sportlines ride". This can definitely be an issue since not all of the GB participants may want to start from that low and only be able to go lower via the lower mount adjustment!!!
I can assume that raising the lower spring perch may be a solution but the adjustable shock/strut body was a big plus for the D2s and was supposed to let you use the maximum available spring travel. Now, lets give an example.
Hypothetical example:
You have 7" 5 Kg/mm (280 lb/inch) extra springs that will presumably be used on the rear coilovers. Again, from Eibach's site the spring travel before coilbinding for similarly speced springs (0700.250.0275 aka 7" - 275 lb/inch) is 4.46 inches. At 280 lb/inch the rear 5Kg springs will compress by 660/280= 2.36 inches by the weight of the car. This means that you will be left with only 4.46-2.36 = 2.1 inches of travel before coilbinding and this assuming you will have the lower spring perches at their lowest possible setting to keep the springs captive. If you raise them by 1 inch to adjust the ride-height, you will effectively remove 1 inch from the availalbe spring travel and be left with only 1.1 inch of travel!!!!
ACE, can you check you rear coilovers and see how much is the total available range of spring perch adjustement on them as well as where they are now? I ma asking because the solution to issues like that is to go to the longest posible springe that can fit in there at the spring rate you desire. If there was enough lower spring perch adjustement range to fit 10" 5 Kg/mm springs in there without compressing them, then you would have 5.99 inches of available travel, 2.36 inches of static car weight compression leaving you with 5.99-2.36= 3.63 inches of availalbe spring travel (instead of 2.1 in the prior case).Quote » No biggie. With stiff *** springs (9 7 combo) the springs don't really compress much when the car is on the ground, which may be why the fronts are the way they are.....[/quote]Do you have your car's weight and weight distribution handy? Just want to put actual numbers on the hypothetical examples to see what is going on.Quote » Performance:With the dampeners set on 3 turns out of 6.5, they're very smooth. I thought that the 9/ 7 springs would be stiffer, but so far they're very bearable. I'd have to say that it might be in part due to the dampeners being able to handle the bumps, potholes, and dips with the 9/7 springs, because there's very little shock from any of those. [/quote]THis suggest that as they are currently set-up D2 is right on the ballpark with their "default" settings. As a side note, they suggest there are 36 points of adjustment so coupled with your 6.5 total turns it would mean something like a adjustment point every 67 degrees of rotation.Quote » I'd still like to tweak the rear end ride height and raise the dampening a little bit. I haven't even gone past halfway yet so it's looking pretty good for now.[/quote] Again, be carefull with this. The hypothetical example I gave above has actually happened to me under very similar conditions. Had 7" 200 lb/inch Eibachs from a GC set on the rear of a B13 and it was too low for my taste. Raised it to stock ride-height and uner medium hard conditions the suspension was very abrupt and jumpy (teeth-griding and all) so I got rid of them. Later on I realized that I had effectively reduced the available rear travel to 1.25 inches and was coilbinding every chance I got!!!Quote » Overall:If you get the 7/5 springs, expect a comfortable ride. The 9/7 springs on my car are far from teeth chattering (although I DO have snow tires on still... the stiffer sidewalls of my summer tires may change that).[/quote] Quote » I would have to say at the moment that the D2's are worth the price they're going for. As time goes by I'll be able to say more about them. Right now I have yet to see how hard the dampening can get..... so it can get a lot better from here, hopefully. [/quote]I know it is a looong-looong-longshot but if you get a chance to "play" with the suspension soon, try to measure the free spring lengths and the available range of adjustability (both shock body and spring perch). From their answer "the range of the length adjustable is 120mm"to my question "Is there a specification available for the free length of the springs? " I assume that they misanderstood and actually replied that the lower spring perch has a range of adjustment of 120mm (roughly 4 inches) but you never know...
Regards,
Chris
