AceInhole »
https://forums.nicoclub.com/aceinhole-u6364.html
Wed Feb 25, 2004 5:54 pm
I blew my diff up on the way to the event on Sunday.... :-( Finally have my VLSD in now, though.
I WAS able to do 3 runs on Saturday at a local event before I had to get to a dyno session. Also finally got some new magnets:
That right there is about all the body roll you can expect from the coilovers. With more spring preload it should flatten out a bit more, but braking through a turn will pretty much be as hard as it gets on these things. I for one think it's very flat, although I wonder what a difference an 11/ 9 setup would make (i'm tempted to try it). I really need to replace the front whiteline swaybar endlinks with something more solid, too.
As for performance, I now have the dampers set at 5.5/ 5 full turns from soft (Front/ Rear). There's still just about a full turn of adjustment left on the front (and a corresponding 1.5 turns for rear), so I think 11/9 may be as much as these things can take. The 9/7 setup is DEFINITELY good enough for track and autocross, though. The visible body roll comes from a LOT of lateral acceleration (R compound tires, 245 wide on all four corners). Really, going stiffer for Autocross would probably hurt more than help, since cracks/ bumps/ surface irregularities will just toss the car around more and your tires will spend more time off the ground, lol.
I still really need to flog these things, since at the last event I found out my rear toe control arms were bent. My rear end HAD to have had some toe out or something. I've replaced the rear arms and the car is much more stable.
Finally, my friend Jimmy just received his set (express shipped) and we installed his AT the autocross event (we don't need to walk the course at such an event. It's small enough and relaxed enough that we just get the general layout and modify our lines while driving). Everyone that passed by commented on how nice the coilovers looked, and complimented on the quality. The mounts are very nice peices! Anyways, here's a copy of his review from our local forum:Quote »Thanks to PJ for helpin' me gettin' them installed 45 minutes before the auto-x started.
I'm still gettin' them broken in (went for a hour joy ride today through some rural roads) hoping to settle the springs a little. The 9 kg/mm springs up front and the 7 kg/mm springs in the back aren't too bad at all...but aren't "comfortable" either...lets just say it keeps the ride very...controlled.
I've screwed around with the dampening a little, stopping every couple miles or so and tweaking. I'm still differentiating between tire bounce, and under dampening. But adjusting them from full soft to full stiff is quite different. Although the ride is still stiff due to the high spring rates, the body roll is much more apparent at full soft. So naturally, next, I tried full stiff, both front and rear, and gave it a good couple miles. Its much easier to point out that the rear was overdampened, but the front still seemed pretty compliant. So who knows what my final dampening will be. I'm running 4.5 turns up front, and 3 turns in the rear (from soft) and we'll see how it goes. Note, I'm also running just stock SE swaybars currently. I need to get back on to auto-x to test it out fully...but so far, they're quite the bomb. [/quote]I hope this helps!! There's a double header event coming on the weekend of the 17th, so I'll DEFINITELY have a lot more to say after then!! After missing the first event of my main season, I'll definitely be milking these things for all their worth at the next race!!
