CoryDangah's ugo40 drift thready
poshatch
Car: p.o.s. 1990 240sx hatch
Update: 08-17-2010
ok so i started off my day by going and trying for the like 5th time to get my car smoged and they said the timing was too low so they sent me on my way (on a side note im pretty much over trying to get this thing smogged...you all know what i need PM ME IF YOU HAVE THE SOLUTION!)
i get 1 block away from the smog place stop at a stop sign, go to turn left...the car dosnt want to turn..
im like aaahhhhhh f***! luckily there was a parking lot directly in front of me so i drove in there. got out. looked to find that the shank on my project silvia outer tie rod had broke...lucky for me it happened when i was going slow and comming to a stop, if this had to happen it happened pretty gracefully
anyway. im soooooo over this shank bullcrap this is the SECOND shank that broke
f*** PROJECT SILIVA!!!
anyway
i decided that im going to make my own shank so that it can put the tie rod sitting more in a proper place
here is a start of what im going to do....you can see the broken one and how short it is in relation to what i will be using still in the brainstorming stage...i cant use the temp jank bolt i used today to get home
here is the mock up of the hydro brake that i created and hopefully it will be in soon working fine..any suggestions on how to get the e brake handle out the easiest way?
here is my t25 that ive had for a long long time that im going to rebuild got the exhaust side off but having trouble with the turbines on the shaft...work that out later
anyway there it is...since i cant pass smog here is a list of stuff to come
hanger being welded on and the victories on the car
obx headers with the egr block off
un-restricted cold air intake system
hydro e brake hardlines install
stephen240hatch
Car: 89 s13 hatch
good job quuer
poshatch
been a long long time,
here is a small update cause i havnt done much at all
bozo's on
what they used to look like
what they look like now
poshatch
and just in case your curious, this is pretty much what i did
although i didn't angle the arm more straight since i don't have a stock stopper i'm also shortening my stopper so that i get more angle that way
plus a few extra things not on there
poshatch
done
turbos i have, the left is a garrett t25 a/r .80/60 i beieve, and the right is a aireresearch (american garrett) i dont know the exact size i think its simmilar to a t28 though, a/r .60/.48
probably going to run the garrett at around 8-10psi probably getting about 200-220 to the wheels
RustspecS13
Car: '74 260z and '88 300zx turbo
You should have angled the tie rod arms more straight like the pic. It changes your ackerman angle and improves it for drifting.
I reduced mine quite a bit but I think I'm going to make another pair of them to try out a different set of angles.
How did you weld yours? If you didn't take a few precautions welding will fatigue the metal and it will eventually fail.
Props for attempting it your self though.
~Alex
poshatch
i think i know what your talking about, i reduced it a little bit but i was afraid of the overall impact of the set up since im not too familiar with what everything does 100% even though i understand most of it i aired on the side of caution
ackerman angle is suppose to be slight toe out when at full lock to keep the car more balanced i think?, i didnt know if changing the angle too much would affect this to a point that i wouldnt like, so i decided that i wouldnt straighten it out too much, new ones if i make any will be a whole new experiment
its going to be way way better than stock that's for sure, they are so messed up stock and im running a larger shank too that isnt tapered, i think the techno toy tuning cars do that at least thats where i got the idea from, both mine and my friends shanks broke right at the threads were not making that mistake again.
im pretty confident in these things. the welds were done with a Lincoln stick welder, we took our time with the welds, cleaning well, inspecting after every pass, adjusting heat for proper penetration without melting the material away
the welds are sound, i dont predict these knuckles having much stress on them or put alot on the shank with the adjustments, if they get as much angle as they should, i shouldnt be hitting full lock all that often (i already got a lot lot of angle on the set up before i modded the knuckles)
but these are my preliminaries, ill find anything wrong with these things pretty fast and inspect, adjust for, or replace with corrected ones
thanks for lookin at the thread its an old dead thread nobody pays much attention too haha hopefully be getting more support when the car is going to events again
J14cm7
Car: 95 240sx S14 SR20det
+1 for trying it yourself although i gotta say im a little nervous for the end result. Nice build though
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
I like the boso pipes lol
poshatch
J14cm7 wrote:+1 for trying it yourself although i gotta say im a little nervous for the end result. Nice build though
thank you for the concern, im always open to critisizm about anything i do so if you have a suggestion or an idea im willing to hear it
im not too concerned though...
as far as i know the only stress exerted on that arm of the kuckle is from the shank of the tie rod and hitting the steering stopper
i corrected the arm so i didnt put as much stress on the shank which usually breaks the shank first, and it should be sitting ok, and the welds i am confident in, i didnt do them, my friend did and although not certified, has countless hours of experience on the welder, much more than me, and it looks and feels solid, but if it never makes contact wiht the stoppers i dont think there will be much force exerted on them, these should produce alot of angle from what ive seen
i coppied the design-ish from drift tengoku vol. 1 so check that ancient thing out
however, ill just have to wait and see, this is a track only car, so if it does decide to f*** up ill be there with emt's and what not should the worst happen
poshatch
uuuuuuhhhhhhh!!
poshatch
picked up a super hurt bumper for 5 bucks so i can complete the kit
the stopper for the new knuckles, the rack maxed out before the tie rod would stop at the FLCA and would pivot out messing up my ackerman steering for the lead wheel so i fabbed these to fix it. The new stoppers stop the "jump" that i had before and HATED, so no more getting stuck at full lock
p.s. if anybody wants to know its 2.5 turns lock to lock (i believe thats the stock ratio) i dont know how much angle but im going to guess around 45*??
the corrected knuckle and the corrected outer tie rod set up with the spacer and solid shank
the front supsension painted and on
continuing painting the back because of the welds
working on a hydro e brake set up, this one is a little different now because i had to change the placement of it so ill post the final product soon
finally the lead wheel with corrected stopper
poshatch
poshatch
small update
poshatch
UPDATE
after so long of neglecting this thread i decided that it would be easier to just move the updates here:
corydangah.wordpress.com
so if your interested in this click the link ^^^^^^^^^
