Copilot
Cjmartz2k
Car: Hunting for a '89 GTR now
ANVIL wrote:
not really. theres a setting for rev limit @ x MPH. so once the car moves it will go back to whatever ur rev limit is
Where the hell is that? I've never seen it. Would be awesome if so
ANVIL
Car: RB25DET S13.5
its not a real launch control, it just changes your rev limit. i have the link at home, but if you search theres a writeup in one of the main the power fc FAQ's that are on the web.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You must have this to use the anti-lag function:
99% of RB25 PFC owners do not have the Pro version.
240z4u
Car: '95 Nissan 240SX
Darius wrote:You must have this to use the anti-lag function:
Darius, what the he l l is that? I have never even heard of it?
Let us know what you find. Ill tinker with it in the meanwhile! When are you going to try the anti lag.
Evan
Darius
That is a screen shot from paulr33's FAQ on the PFC. I don't know when I going to get at the launch control test because I'm booked solid thru Sunday. Might get after it Sunday afternoon. I will definitely keep the thread posted. If I get it to work, I guarantee a video. I know my video guarantee is worthless, but it'll be different this time I promise!
300Plus
Car: 1995 S14 w/ Rb25det Series II
StricNyne wrote:ahh i remeber talkin to JON POWELL about this a while ago, the racebread link is dead, but once i saw the name paul in the link i know exactly who has it... paulr33 from SAU, so i got a link to him !
helps when i put the link in
http://paulr33.skylinesaustralia.com/
MAN!! I remember having this convo with Jon, and on the boards. I saved the old version somewhere...
StricNyne
post or BAN lol
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
I'm messing with Copilot today. I got auto-tune to work at idle. I'm sure it will work at cruising speed as well, I just haven't left the driveway yet.
Launch control seems to work too. I set the launch rpm at 2,000 and mash the gas and it sounds like a two-step and sticks at 2,000rpm. I tried it at 3,000 and quickly at 4,000rpm as well, seems to do its job. I can't see how much boost I'm gaining though because my boost isn't logging when Copilot is running, not sure why. I blame the fact that I just switched from an Apexi boost sensor to a GM 3bar. I don't have it configured just write yet. FYI, I switched to GM 3bar because I broke my Apexi sensor . I pulled the motor out of my car with the vacuum line still attacted.... stupid.
I'll try it on the road later this afternoon.
ANVIL
Car: RB25DET S13.5
sounds awesome.... how does that auto-tune work?
cdorhout
Next project TBD
Just an update.
I couldn't get copilot to auto-tune this weekend on the road. I didn't put too much effort into it, but it doesn't seem to be writing to the PFC. I'll try more when I have time.
240z4u
Thanks for doing the legwork! I really appreciate it.
Let us know the status of the launch control stuff too once your boost sensor works.
Evan
240z4u
I was gonna go mess with it two nights ago but I couldn't find the launch control part. Do I need my VSS hooked up?
Evan
StricNyne
imma buy dataloggit and try this soon
Darius
You need the signal from the gauge cluster to the ECU for the launch control to work. So yes you need the VSS to go to the gauge cluster and then to the ECU.
BTW he put a new version out 3_3_1 or something.
cdorhout
Next project TBD
Yes, if your ECU doesn't know about your speed, launch control will not work. The one bad thing about this type of launch control is you need a laptop running in your car for it to work.
Darius
Damn I was wondering that. I was hoping he could hack the Pro software and write it to the PFC or "unlock" it or whatever. So we'll have to have a laptop with when we hit the drag strip? ...bleh.
240z4u
Darius wrote:Damn I was wondering that. I was hoping he could hack the Pro software and write it to the PFC or "unlock" it or whatever. So we'll have to have a laptop with when we hit the drag strip? ...bleh.
I log every single pass I make, not sure what the big deal is here. Just plug it in, and toss it in the back seat! Not like I want it on the street anyway.
I mean, crap its pretty much FREE! lol
Evan
ANVIL
Car: RB25DET S13.5
any updates on this? launch control for free sounds awesome. also how does the auto tune work? does it just fix ur afr or what?
Darius
There's a fuel map, ignition map, and AFR map. You set the AFR map up for what you want your tune to be based on. Instead of using a spreadsheet to manually change the fuel map after each log, the autotune feature adjusts the injector durations automatically and on the fly. The igntion timing feature will also add timing to each cell until knock is detected. When knock is detected, the timing will be backed off.
There are several parameters and settings that need to be input before tuning, or at least review the defaults. And I believe you can use autotune without it tuning the ignition map.
ANVIL
Car: RB25DET S13.5
i think id do the ignition on a dyno. just because you advance the timing and its not knocking doesnt mean you are gaining power...
the afr/injector adjusting sounds cool though. could save lots of time
Fearsome_tea
Sorry I have not been on in a while i am in transition of changing jobs, leaving Japan but I will get more info soon and post updates
ANVIL
Car: RB25DET S13.5
sorry to bump an old thead, but im still interested in this... maybe i should start messing with this myself once i get my car up and running good. just wondering if anyone has been using this or if anyone has anymore information on it.
gawdzilla
Car: none
any updates to this? my driveability tune needs a lot of work
240z4u
I gave up on it.
Launch control does not work in my car either. I don't think autotune works properly either.
Fearsome_tea
auto-tune works fine for me.
240z4u
Are you the one that was posting on the thread at spyderchat working with Kevin to get it to work right? What box are you using and what motor is it you have? Maybe Ill try again. From what I understood the autotuning "worked" but would not save the changes.
Darius
cdorhout was posting in that thread a while back but I don't know where he left off with it or what the issues still were.
cdorhout
Next project TBD
yeah, but I haven't touched Copilot yet this season. I may look again at it, but I lost the patience for now.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Copilot work with the Apexi box too or just the FC logit box?
240z4u
Software is designed for the power FC datalogit box specifically
