ThuG LyFe wrote:chub,
how do i go about replacing the front tho? i would get the covers it's just that i don't want to take the cover off by baking it or w/e and then put them back on. but i'm guessing i have to do that right?
it should only take you 30 mins max to do the swap. set the the oven to 300-350 (takes most of your time) when it get there put the headlights in for 2-3mins (watch) and then take them out. they will be hot. then put the new covers on and seal with window sealer or headlight sealer. put masking tape on the covers so you don't scratch them and use a zip tie to hold it tight. let it sit over night and put back on the car. good to go! it is very easy most people are just afraid of the oven part
/thread jack
