RB Parts For Sale
– R34 RB25DE Neo Cylinder Head (machined, no cams) $300 plus shipping– R34 RB25DET Cylinder head camshaft oil splash covers, gold in color, 4 of them, $25 shipped– R34 RB25DET Exhaust camshaft. Make offer– R34 RB25DET Head studs OEM used, not sure of mileage. Make offer $60 shipped– R34 RB25DET timing belt Tensioner & idler (used, came off shortblock, unsure of milage)– R34 RB25DET Water pump (used, came off shortblock, unsure of milage)– R34 RB25DET Oil pump (used, came off shortblock, unsure of milage)– R34 RB25DET Oil filter tree (used, came off shortblock, unsure of milage), temp & pressure senders– R34 RB25DET turbo manifold OEM $80 plus shipping– R34 RB25DET Neo OEM top feed injectors 370cc - 150 shipped– R34 RB25DET upper intake plenum gasket rubber, have two of these $20 shipped– R34 RB25DET RWD Oil Pan, Great shape. 150 plus shipping
– R34 RB25DET Blocko .40 Over Bore, Line Honed, Deck Re-surfaced & Micropolished o R33 RB26DETT Crank, longer Crank Collar for oil pump driveo R33 RB26DETT Rods, Micro-polishedo CP 87mm RB26DETT Pistons, 8.5:1 Compression, CP Piston Ringso ARP Rod, Main, Boltso ACL Race Rod & Main Bearingso Tomei Oil Restrictors
o Cylinder Bore Size 87o Piston Stroke Length 73.7o Head Gasket Bore Diameter 88o Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -0.5715
o Make me an offer, something reasonable. no loballers. lots of time and money went into this build. If someone wants the internals, I’ll part it out but only if many of the parts are purchased. I don’t want to get stuck with parts because you want one screw. :p
– R34 RB25DE Neo Cylinder Head (machined, no cams) $400 plus shipping (
zerothread?id=418112 )
o Ordered this head straight from japan, spend over $500 at the machine shop on it, had the following performed: Pressure test, leak test, Valve Job, Valve Seals, Solid lifter Adjust, Resurface, Cleaning
S14 PARTS FOR SALE
– JDM Navan S14 oem front amber corner lights, new in box, $70 shipped– S14 Radio brackets, slightly bent, still work - $20 shipped– S14 left front corner light, broken top tab, and small internal crack. $30 shipped– S14 oem used rear traction rods, $30 plus shipping– S14 Stock rubber shift knob, dirty, needs some cleaning up, $10 plus shipping– S14 sunroof assembly, minus fiberglass trim ring around edge of glass. Comes w/ drain tubes $ Make offer, prefer pickup only, large item– S14 SE sunroof headliner, great shape no stains, cracks, etc. Pick-up only, large item $20– S14 SE sunroof headliner trim ring around pull shade, $20 plus shipping– S14 SE overhead light console with sunroof switches $20 plus shipping– S14 M-sport D-style FRP +20mm wide front fenders new in box, $280, buyer pays shipping, large box approx $150 to ship– S14 SE airbag control module $90 plus shipping– S14 SE airbag control harness $50 plus shipping– S14 SE passenger side airbag, $100 plus shipping– Old version of Pioneer DEH-P4100 Radio w/ aux input CD changer adapter, speaker outputs on harness are chopped off, but was used with external amp so didn’t matter. Just need a new harness if you want to use the speaker outputs - $40 shipped– 5-bolt turbo downpipe gasket, with brand new bolts $20 shipped
Modified by sickness14 at 7:35 AM 4/13/2010
