CLASSIFIEDS THREAD! Read Rules Before Posting!
matafied
Car: 1989 240 rb25det 1992 240 rb25det
Rb25det fuel injectors and fuel rail, OEM factory rail and injectors 75 shipped
[email protected]
3bar_dc2
I posted this up in the cars for sale section, but figured this would be a good spot as well. I finally got it running with all the bugs worked out.
I'm selling my 95 240sx with rb25det series 2 engine swap. I was trying to sell the car a while back with a gt35r setup that was unfinished, but decided to get it going with the stock turbo setup and put it back up for sale. The car is now in running condition. The car started off as a stock automatic. The car is clean title and the chassis has 204k on it. I've only put on about 2 miles since tearing the rb25 down and swapping it in. The body is in good shape, with the exception of paint scraped off on the driver side of the bumper, and the hood being black.
List of things done -
I tore the rb25 down and intalled
-new oil pump
-new water pump
-new tensioner and idler pulley
-power enterprise timing belt
-ARP head studs
-complete oem gasket kit
-z32 thermostat
-block off center oil feed to head
-new spark plugs
-replaced all fluids
List of mods
-Zerolift Autolab rb25 mount kit
-1 pc. steel driveshaft w/ Spicer parts.
-Titan motorsports sr20 3" downpipe modified
-3" test pipe
-ISIS front facing intake manifold
-Q45 90mm throttle body
-Spearco 28"x11"x3.5" core
-Full 3" intercooler piping
-ACT 6puck clutch kit
-Nismo transmission pivot ball
-Catch can w/ bung welded to oil pan for vta
-Walbro 255lph fuel pump
-RB25 series 1 turbo
The car is a great foundation for a build, whether it be drift or drag. The engine is currently running on stock boost, maf, and ecu. The car should be pretty maintenance free from here on out as I wanted to make sure all bugs were worked out before I posted it up for sale.
Asking $8k obo
Thanks,
Sean
505-720-9702
[email protected]
meet07
Car: 89 180sx rb25det
stock manifold:
rb25det stock turbo header: $50.00 + shipping
[email protected]
Shocker
Car: 89 240sxHB rb26/30
UPDATED 8-10-10
Rb25 Intake Custom Intake Plenum for SOLD SOLD SOLD
Made by Custom Plenum Creations in the AU. The manifold is polished on the plenum, velocity stacked, welds in the ports are all smoothed, hand tig welded aluminum, its about 1500 miles used. No problems what so ever with this manifold it was great, but unfortunately I'm moving on to other projects. Manifold comes with Q45 TB, no TPS though. Looking to get $600 shipped to the lower 48. For what I paid for this piece originally it is a steal.
Microtech LT12S
Mircotech LT12S ver. 10.0
3 Bar Map Sensor on board
Rb25det base map installed
"The LT12S is Microtechs' latest 6 injector driver, 6 ignition driver ECU with multiple Auxilliary inputs and outputs. Most often used on 6 cyl and 3 rotor applications but also can be configured for 4 cyl vehicles. "
ECU ONLY NOW $500 shipped it needs to go make an offer!to the lower 48 states.
If interested in either or have questions, need more pics whatever, email me at [email protected], we can work something out.
Thanks,
-Cory
blongi
Car: 1995 Nissan 240sx SE
Want to buy stock RB26 injectors. Let me know if you have a set or someone who does for sale. Email is [email protected] Thanks in advance.
Blongi
meet07
T28 sold locally today!
wakotow
Car: '93 240sx S1 RB25 + HX35
sold
GSDKinked
Car: 1997 240SX LE
jrd450r wrote:
GSDKinked wrote:I'm gauging interest on this.
$410 shipped OBO
What size injectors? Side feed? Hi or Low Impedance? Thanks!
72lbs and low impedence
toadx8u
Car: 1975 Datsun 710(coming soon F20C)
1993 240sx Vert DD
1995 240sx GT3788 RB25DET
1996 240sx LSx 5.3L
2000 F-250 Crew Cab Diesel
2004 Honda RC51
Selling:
RB25 power fc with controller 1k...or with datalogit for 1200...
import intelligence 2-step...150
GT3076R w/ultimate internal wastegate and 14# actuator (i can powdercoat this for an additional fee...hot and cold sides)...1350
I also have various stock RB parts...too much to list
All prices are + shipping
email me [email protected] or text me 302-416-0577 and I will get you pics
Thanks Todd
GSDKinked
Car: 1997 240SX LE
Type VA18-AP70/LL-86S 12V
Selling because I went with a clutch fan set up instead. Very powerful fan, excellent for controlling engine bay temps. Just a bit more than I need.
$50 shipped
.48 Turbine housing off of a AGP T3/T4 turbo (delta 48 similar to 30R)
$50
Pics will be up tomorrow.
eh?
[email protected]
Q45 throttle body. Needs the set screw. Sensors and fast idle removed.
$30
Rb25 Series 2 coil packs, made 437whp with these.
$90
NEW RB25 Series 2 coil pack
$60
Quest alternator
30 (shipping is expensive)
RB25 rods/pistons with ARP bolts. Pistons need to be removed and bolts installed. These are correct bolts for RB25 rods.
$80
Cometic RB25 rear main seal
$10
Another Q45 TB but complete, has all parts (no bolts). $50
Q45 MAF $25
RBTALLY
parting out the RB car everything is for sale that is Nissan related... to start off the whole car can be had for 12000. turn key it made over 600 to the wheels through a auto trans without the nitrous ... the motor complete from intake to pan and header with turbo nitrous and all intercoller piping and the liquid to air intercoller, also includes theTail 44mm waste gate,Tail 50mm BOV, external oil pump and the ATI ballencer with the crank trigger built into it....5500.00 the trans setup which is a 2 speed powerglide with a transbrake ans ATI 10" converter, ATI adapter with SFI flywheel and Chetta shifter 2500.00 the computer is a FAST XFI with the XIM box to run the ls1 coils I payed over 3000.00 for it I will sell it for 2000.00..... If you buy the car complete you can have anything nissan related even the parts laying around form my GTR. there are too many cars in my shop and this one is my least favorite. no trades email me at [email protected]
meet07
im selling this rb20 and 25 ebay turbo header that has been flanged for a t4
ebay manifold: $150.00 shipped
Z32 maf meter with pigtail: $100.00 plus shipping
[email protected]
919-818-1864
StricNyne
WTB Series II Rb25DET Complete Harness. I have a series 1 harness and coilpacks, a rb26 harness prewired for a s14, and a few other things i will trade, i need this harness bad though. contact me via email [email protected] i got ton of spare parts too
EJ8 944
Any interest in selling that RB26/S14 harness? Who did the work on it?
StricNyne
carl did, it works good, just i have a rb25 and i want my vct back lol, hit me up on email so we dont clutter this thread, [email protected] or call me at 732 552 1467
bRadical
Car: maroon 95 240 RB inside (Eatn By The Dragon)
black 95 240 RB25inside (running by 11-18-10)
i need a stock turbo... not in any kind of hurry as im goin outa town for damn near a month but deffinetly wanna line somethin up to ave it sittin here for my return pm me if u have one with shipping to 28021! thanks!!!
Kevin.A
Car: Nissan 300zx RB20 swapped
WTB 7 pin Igniter connector, A+ shape Image
Shipped to 08820
Thanks
Kevin A
jedimind240
Got some random parts im trying to get rid of.
RB25 OEM dump pipe. $10+shipping
Stock RB25 Clutch Fan $8+shipping
Stock RB25 BOV $10+shipping
Also have a stock RB25 oil pump. $10/obo +shipping
I also have a stock RB25Det upper intake manifold. $10+shipping
all prices are negotiable. You can email me at [email protected] or txt me at 812-457-6871. Im Jt so you know. I also some s13 hatch parts if your interested. Thanks
Xit40
Car: 1998 Mitsu Eclipse GSX, 1992 Nissan 240sx
WTB: RB25DET Power steering bracket and adjuster in NY. I have a pump so no need for that. Please contact me ASAP at prickle93 at hotmail dot com or PM me if you have one you want to sell. I am a confirmed Paypal user.
DETurbine
Car: Nissan S13 RB25
I have a HKS SSQV RB25DET flange. I am taking the flange off since I have a custom setup now that takes the universal flange. The 1g dsm flanges go for $60, I am selling this $40 shipped (via regular usps). Email me at [email protected] if interested.
meet07
Kevin.A wrote:WTB 7 pin Igniter connector, A+ shape Image
Shipped to 08820
Thanks
Kevin A
I have that plug at home. I was gonna wire it into my harness b/c mine was messed up during shipping. It still worked so I didnt replace it. but hit me up for a price at: [email protected]
jrb92se
Car: 1989 Nissan S13 coupe
i need to buy an rb25det pcv llines both the one that connects the valve covers and the one that connects the intake valve cover to the intake manifold any reply appreciated and my email is [email protected] im not tryin to run a catch can
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Wanted:
Rb26dett turbo coolant lines.
The lines from the side of the head to the actual turbos, the line that T's into those lines, and the lines that wrap around the back of the head. Basically all the hard coolant lines.
Except for the lines that go from the block to the turbos. I have a set of those.
Send me a PM or email me at [email protected]
Thanks.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
wtb lower timing belt gear for a r32 rb26dett
best way to contact me is either thru
[email protected]
or
3526652496
BoredEE
WTB stock turbo for RB25 S1 or S2.
NVM, Got a new one at nissanparts.cc
platez808
Car: 1989 Nissan 240SX
wtb rb20det/rb25de transmission shipped to 96706
pm or email at droppingplatez808 (at) gmail (dot) com
HPF Chrisk
Car: 240sx
Rb26 mani with adapter plates to fit on a rb20/25. Requires top feed injectors. looking for 900obo
Rb26 mani and throttles, no lower mani. great for itbs on your rb20/25 with custom adapter plates and your lower manifold. Would alow you to use your oem sidefeed injectors. 400
Dakota digital tach adapter - 40
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Im thinking of parting with my new project before its even started. Is anyone interested in buying my rb30/rb26 combo that i started and lost interest in. Im getting tired of build and then having to work on it.
Rb30/26 pacakge deal-----3,000
Rb30 series 2 short block in good shape (has ports for turbo lines, water pump, oil pump, timing gear, tensioner, idler pulley, front lower cover, harmonic balancer, power steering pump, a/c pump, oil pan, and flex plate.)
R32 rb26 head and electronics( comes with v/c covers, upper front and rear timing cover, complete valvetrain, cas and bracket, Throttle bodies with plenum and all hoses, harness,etc.)
The package includes basically all the parts to put the engine together besides, turbo stuff, ecu, and mafs.
email me at [email protected] for more info if needed.
sickness14
Car: 95' S14 SE. RB25 Neo. ARP, Tomei 260's, HX40 Pro, PFC, Synapse, Greddy
S14 / RB Parts For Sale
– R34 RB25DET Neo Exhaust camshaft. Make offer
– RB25 Head studs OEM used, not sure of mileage. Make offer $50
– RB25 neo upper intake plenum gasket rubber, have two of these, $18
– R34 RB25det turbo manifold OEM $80
– RB25DE Neo Cylinder Head (machined, no cams, no cam caps) $150 plus shipping zerothread?id=418112
May part out the block depending on what i get offered for the various parts.
fresh never run completely assembled. Sitting on engine stand at the moment at a shop.
R34 RB25DET Block $1,800
.40 Over Bore, Line Honed, Deck Re-surfaced & Micropolished
R33 RB26DETT Crank, longer Crank Collar
R33 RB26DETT Rods, Micro-polished
CP 87mm RB26DETT Pistons, 8.5:1 Compression, CP Piston Rings
ARP Rod, Main, Head Bolts
ACL Race Rod & Main Bearings
Tomei Oil Restrictors
also have the following RB25 parts but they're used:
-oem water pump $50
-oem oil pump $50
-oem tensioner & idler pully $40
-oem rb25 rwd oil pan in great shape $100
