Cbus240's Restoration/Build Thread 56k
tEknoS13
Car: 93' Type X
Nice nice nice. Cbus, may I ask about your turbo oil return tube? Did you clock your turbo? I'm having an issue with mine, I however have a gt2871. I noticed yours is at an angle and the tube lines up perfectly with the block fitting. Mine is facing directly below so both the block fitting and the turbo tube sit at weird angles making it impossible for the hose to be placed. I can put a longer hose on there but it gets in the way with the steering shaft or it may kink... Any ideas?
