gadget1382 »
https://forums.nicoclub.com/gadget1382-u100652.html
Wed Aug 06, 2008 6:48 pm
You can essentually make up your own mounts using 2x (L&R)
3x High tensile bolts3x Lock Nuts6x Washers3x 6-8mm thick rubber Disks, 70mm Dia4x 2mm thick metal Disks, 80mm Dia
Drill through the centre of each of the disks (metal and rubber) and bolt together in a sandwich manner.
Drill 2 more holes right through all, on opposite sides of the center bolt.
Then when mounting, put the two bolts through the k-frame mount/bracket and the single centre one through the engine mount/bracket.
If need be, you can drill a larger holes in the outter disks to "countersink" the bolt heads. Though if doing that, i'd increase the number of disks (both rubber and metal by at least 2 each side.
Bob's your uncle... DIY engine mounts.
Modified by gadget1382 at 10:12 PM 8/6/2008
