allmtoreg wrote:i hope your joking
LolzFlatBlackIan wrote:Its a speed hole.
thats what she saidnissanman04 wrote:throw it back in, it's fine
actually, didnt make any noises, not even when it happened, just a ton of smoke, but after it started, i drove it another 50 miles, then did 2 burnouts, then it wouldn't run anymore. :oB-Metts wrote:i bet that made some epic noises.
I should do something with it. lol Hmm ideasss!?dre1507 wrote:i say you take duff's advice, buff it out, polish that sucka and make a wicked kool shift knob.
fugg that. I got eagle rods, arias pistons, i'm sending it all out to get balanced, getting some headwork done, then going to town with more boost! moar boost! lolILoveMyRHS13 wrote:I was wondering when you'd blow that thing up.
I've got a set of SOHC pistons if you wanna run lower compression, haha.
OK OK OK I hope your joking...Otherwise you have been putting out WRONG information in these threads...ILoveMyRHS13 wrote:I've got a set of SOHC pistons if you wanna run lower compression, haha.
yes, so other than a paper weight, what can i do with this piston. its the first one i've ever blown a hole into.ILoveMyRHS13 wrote:I'm used to researching SOHC's. DOHC pistons lower compression on SOHC's.
Back on topic.
It'll be like the 80's I'll just carry it in my back pocket till someone talks s***. hahaILoveMyRHS13 wrote:Throw it at things?
That's what I do at the junkyard.
