CA18.5DET Build-Up
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I went to the dealership and got the part number for the CA18 rod bolts. They do not cross reference with any other Nissan rod bolts, so they would either have to be re-branded ARP bolts from another application, or specially-made.
Mag, you say you bought them and they fit well and everything?
sicj
Car: 1987 Nissan 200sx hatch, 1992 240sx coupe
yeah I really wanted to swap to ARP rod bolts while I was building it too. I asked ARP and nada... But a good thing was my caps didn't stretch prior so I guess the stock bolts are pretty tough. Deffinitely would be nice to have ARP quality bolts in them though.
Mounted up the Maxima Alternator today:
Pulley Diameter:CA = 2 15/16"Maxima = 2 11/16"....more output @ Idle.
As you can see the mounting at the top of the alt. is VERY different so I made a custom adapter bracket to bolt to the alt. I also found a mystery piece from the motor that I had in a box that happened to work very well to adjust the alt. tension...
Block/Oil pump mounting = exact!
Final Mounting
how it works
themadscientist
Good stuff right there, thanks for the how-to.
magmonster
Car: 67-PL410 (bluebird) / CA18DE-T
I have them at the machine shop right now, but I'll head down tomorrow or Saturday to check it all out. they looked the same when I got the package. the ARP hardware was black though.
I was waiting on pressing them into the rod, but I'll make sure they fit and post up the results asap.
r34 gtr wrote:I went to the dealership and got the part number for the CA18 rod bolts. They do not cross reference with any other Nissan rod bolts, so they would either have to be re-branded ARP bolts from another application, or specially-made.
zero_gripS13
Car: soon to be 95 s14 hopefully
that looks simpler than what i was thinking and i could just go that route lol.. thats a throttle cable bracket right...
thats a genious idea.
sicj
zero_gripS13 wrote: that looks simpler than what i was thinking and i could just go that route lol.. thats a throttle cable bracket right...
haha your right! That is the throttle cable bracket. I couldn't figure out what the hell it was... Ah the car won't be running for months anyways, that's enough time to find another one!
zero_gripS13
hows the belt alignment with that alternator? can u use all 4 ribs or is a 3 rib setup... i guess u follow one of the golden rules closely "keep it simple, stupid"
themadscientist
sicj, this is you ain't it?
sicj
you can use a 4 rib.
The back of the pulley is in line with the back of the crank pulley. So it's offset is exactly the same as the Ca alt.
one thing I cannot test however is if you can retain the use of the stock size belt
sicj
themadscientist: haha! I'm more of a MacGyver jr. No one can top the original OG!
dash
Car: s13 ca18
magmonster wrote:But, the ARP rod bolts are way better than the stock units. Even if they aren't wav-loc, or the newer alloy. I'm pretty sure that these are a really cost effective upgrade, seing as how rods bearing/bolt stretch seem to be a common point of failure in the CA.
maybe for sustained high rpm applicationsDoubt rod bolts has anything to do with the CA18 chronic rod bearing failure for everyday use. Sooo many other reasons pinpointed.
magmonster
My machinist told me that both con-rod#4 bolt(s) failed (stretched), causing the bearing failure. It wasn't bad, the PO shut down the engine right away and the crank regrind was minimal. the bearing didn't completely fall apart, but the piston took damage from the flopping off-balance mass of metal.
If there was anywhere in an engine that a good bolt is required, I think fair to say the con-rod is the best place for it.
-Cheers.
dash wrote:maybe for sustained high rpm applicationsDoubt rod bolts has anything to do with the CA18 chronic rod bearing failure for everyday use. Sooo many other reasons pinpointed.
sicj
I spiff-a-fied the coil pack cover. I agree with most on here that the coil packs need to be vented to live a long life and maintain performance.But I just couldn't let go of the cover, I had to run it. It just looks so nice.
So I vented the stock cover and painted it up.
shows where I would vent the cover
looks like shiet
vented and all new paint
I get the best of both. Vented and stock looking. schweet.
turbo/IAC line are up next.
davidricardo86
Car: 1992 Nissan 240SX SE
Not bad! Not bad at all. I enjoy this thread very much. Keep em comin
Oh and the Maxima alternator find was excellente senor!
float_6969
Yea, I really like the Maxima find. and the vented cover looks awesome!
jimmyD123
Car: 1993 240sx
what year maxima is the alternator from?
bimeur
Car: rs13 '94/ca18det
Hi,
some news about this block???
your unknown parts,that you used for the alternator,is the support of the gaz cable,near the TB
ska69
Car: 200sx s13 ca18det
the maxima is alternator great! where did you get the alternator bracket? did you fabricate it yourself? (the one on the alternator body)
and also, did you check if you can retain the use of the stock size belt?
sicj
no new updates on it unfortunately.
I picked up a '71 240z and have been putting money into that. But Imma go against the norm and throw this engine in the Z eventually.
Yeah for the top Alt. mounting I used the throttle cable bracket bolted to a custom adapter piece that I fabricated that bolts to the Alt. housing.
I have no idea if the stock belt will work, since I am not using a belt driven water pump. That pulley is missing.
One thing I did notice is due to the new alt. and no stock water pump, that the belt routing will interfere with the timing mark "pointer" on the front cover. So I will have to grind that off and drill a hole higher up and use something like a 2/56 screw as the "pointer" now...eh, it's all custom anyways. lol.
ska69
240z is good
any suggestions for your followers on the maxima alternator setup?
mbmbmb23
sicj wrote:no new updates on it unfortunately.
I love your coil pack mod, I might have to copy you =) (although I will JB weld come black mesh screen underneath) Good stuff!
