Our motor are 100% guaranteed against any failure due to workmanship by us or the machine shop.
In a perfect world where there are no issues with fuel delivery, timing, installation errors, etc, it would be easy to guarantee a motor against everything. Unfortunatly, its not a perfect world. So we wouldnt be able to eat the cost of melted pistons, bent rods, bearings damaged due to lack of oil or detonation. We will however reserve the right to help customers that have bad luck in those departments.
We have been building cars for the past 15 years. My experience goes back to the early 80s when I was working at my uncle's shop Chicago Engine Rebuilders. I was bitten by the bug and have been working on cars since then. I have owned probably close to 40 cars in the past 20 years that I have worked on and modified. I have been the shop forman at Sound Performance for the past 5 years. I dont just sit behind a desk and order parts or watch others work on cars. I am actually out in the shop and working on cars, developing new parts, solving problems, etc.
I will personally build every motor that we sell (as I have been doing for the past 5 years) My experience ranges from stock rebuilds to our 1300 crank HP monster 2JZ motors. I have done VG30detts (currently building one for one of our shop cars to hit 800whp) and many other motors including the SBF motor that just made almost 1400 crank HP on an engine dyno. I have all the tools necessary to measure, mic, gauge, file rings, etc.
Our automotive machine shop has been around FOREVER and has been doing all our machine work for the past 15 years. Bill is well versed in HP engine machineing. We recently had him build a deck plate for the KA to get the most precise hone possible. He is fully capable of going as crazy as you would want to go with coatings, o-rings, knife edging, cryo, vibration, magnetic resonance, etc etc... The sky is the limit.
We also have one of the best head porting companys in the country an hour drive from here. We use this company for all our race prepared 2Js.
I know its hard to think about investing 4k+ into a motor with no guarantee other then our reputation, so please check us out (
http://www.sound-performance.com ) and let us know if we can help you build a 240 you (and we) can be confident in.
Lastly, Yes, you can send us your cams and we will install them in the motor we build for you at no additional charge assuming no lash caps are needed. If they are stock base circle cams then we will be able to adjust them with factory shims.
