fo0manchu wrote:I plan on using no FMIC. Due to space constraints in my engine bay. My understanding is that pre turbo injection will keep the air charge coming out of the compressor as close to ambient air temp. There will be low enough volume that most of the water will be vaporized upon exiting(even better results can be had with alki or meth mixed in to help vaporization). Resulting in the compressor running much more efficiently. Then a second nozzle will be switched on at a higher boost level pre throttle body.
I think most people use pre throttle just because its the easiest, cheapest, almost fail safe, and can be done on a budget. Pre turbo takes a bit more planning, tuning, and $$$.
But I guess since this is a budget thread, pre turbo should be in another subject.
Oh, well not using a intercooler changes everything
I was doing some more thinking on this, because I like outside the ox thinking, and found TONS of nozzles that will provide a nice mist. Several low GPM nozzles that will spray a great mist as long as you keep the pressure over 50psi or so. Pressure being the key. But almost any shurflo pump that pushes more then 2 GPM will work, I recommend the 4 GPM pumps because they will handle any amount of extra nozzles you decide to add later.
With no intercooler I'd actually do either a 3 stg setup with 3 small nozzles and a high pressure pump. The initial pre-turbo nozzle actuating at about 1-2 psi so the "chilled charge" reaches the intake mani by 4 psi at the latest and keeps the intial temps down so you don't have to worry about timing retard at all. Then use knock or whatever to determine the next 2 stages that will be pre-tb. Probably 7-8 psi for stg 2 and 12ish for the final stg. That would allow for 14 psi and an easy 350whp. Kinda makes me think about it more...especially if it does change the effective AR of the compressor.
Or 1 pre-turbo nozzle with a fixed pressure and 1-2 psi onset combined with a single pre-turbo nozzle that's hooked to a variable controller.
Lots of options.
Check out this controller.
http://www.labontemotorsports.....html
