theoreticly you could put a coupler OVER the hole to plug it(least it would look better than the electrical tape)sjbsuperman1425 wrote:as my family says, you are what you lol no im just kidding
what type of places would be able to weld aluminum? i think i may have someone cover the hole and then weld it on the other side, it seems like the best way to go.
ca18detgabby wrote:otherwise cut, rotate 45 or so degrees, and have a metal shop weld it back together........ it should be easy for them to cut rotate and weld it back together since it isnt a point where it turns.
ECHO ECHO ECHO ECHO ECHOMeanGreenS13 wrote:cut that piece of pipe and re clock it. then grind down the welds, find someone with a polishing wheel and knowledge of polishing aluminum. and go to town. problem solved.
Im just a d!ck. sorry, thats just me.
MeanGreenS13 wrote:ECHO ECHO ECHO ECHO ECHO
^^can't cut and rotate it wont line up with the TB.sjbsuperman1425 wrote:the pipe does turn a bit into the stock ugly black coupler thing
aluminum, or the cheapest thing they got? cash is short for now, and this is what im working with until i get some lol thanks for the input once again guys/gabbythemadscientist wrote:Go to a muffler shop and have them make a new pipe. The whole thing is wrong. You save youself all the problems by just starting fresh.
that was real ghetto well I waited for mazworx to get a real coupler in.....sjbsuperman1425 wrote:^^hey Gabby, where did you get that piece between the TB and pipe?
cut above and below the flange...... then rotate......... 2 welds and bam it is the same.sjbsuperman1425 wrote:
again the SAME EXACT THING that i said...ca18detgabby wrote:]
a new pipe will solve your problem too.
desiel trucks is what the dude said.... he told me I was crazy and it would never work.......sjbsuperman1425 wrote:they make heater hose that big??? i wonder what for?
did I say it WASNT? he wasnt getting it so I tried to re-word it.MeanGreenS13 wrote:
im a literal person, sorry..ca18detgabby wrote:did I say it WASNT? he wasnt getting it so I tried to re-word it.
thanks have a nice day..
little high heat paint and noone would ever know the difference.r34 gtr wrote:My whole intercooler piping setup is made from 2.5" Auto Zone mild steel exhaust tubing. I think it cost me $30 TOTAL and it holds boost fine. Also, it doesn't matter if the stuff leaks because I am MAP based! Yay!
Seriously though, AZ exhaust piping (pre-bent) and plumbing couplers/fittings from Lowes/Home Depot. Its not winning any beauty pageants but it does get the job done.
can you get a close up pics of your setup??r34 gtr wrote:My whole intercooler piping setup is made from 2.5" Auto Zone mild steel exhaust tubing. I think it cost me $30 TOTAL and it holds boost fine. Also, it doesn't matter if the stuff leaks because I am MAP based! Yay!
