Empty V wrote:
Actually there's a massive difference. If you knew about what cables I'm talking about then you'd know, since your talking out of your a** you don't. It has to do with how the shield is wound and at what speed frequencies are transmitted due to the shape of the winding. But thanks for your input. The same principal as Sku Free.
I didn't really want to deal with this after my nap, but I guess I will...
The power cables that you are talking about connect your piece of equipment to the wall. Typically a 6ft span.
Depending on the size of your house/office the main run from the panel could be in excess of 100ft. This is typically standard Romex 14/2 or 12/2. There is no shielding on this run. Don't even get me started on the distance from the mains to your building....
So you are replacing a 6ft section out possibly a couple miles of wiring.
Open up your piece of equipment and look at the connections that are soldered to the power plug. You will find that it is probably an unshielded low strand piece of wire that splits with one leg going to the circuit board and the other to the mains on the transformer(on an amp).
Feel free to enlighten me on anything you'd like.
@other people: Here's a link to their brochure.
http://www.taralabs.com/images/stories/ ... -Cords.pdf
Here's the company that we carried at Sound Advice.
http://www.audioquest.com/ . Notice the similarities...
