Anton corrected himself nicely,
You can gap Iridium plugs, but in many cases don’t need to. I currently run the NGK BKR7EIX in my Sport500 TT. I run 19PSI with methanol spray and have a Specialty Z custom tune. The car runs like a dream. I could run 22PSI if I wasn’t a n00b who gapped my 0.030” iridium plugs to 0.035” before installation. Don’t be a n00b, heed what we say and save some headache.
15PSI is the safe upper limit on stock injectors. With upgraded 615s, you can go to 16PSI, but I wouldn’t go any higher than that. This is all assuming you have 93 octane fuel available. If all you have is the 91 octane Cali or Maine piss, then your upper boost limit is 14PSI.
From the man himself.
Set your timing to 15 degrees before TDC and leave it. NEVER change it, there is never a need to do so. If you need to retard it to 13 to avoid detonation, your tune sucks and you need a new EPROM.
Welcome to Nico, hope you find us helpful and useful!
