Please don't use Z1 as your be all end all of 300zx knowledge, though they are a good shop, your majority of best knowledge will be found with folks like Greg Dupree, & Seb from Specialty Z as well as Kyle at IPP and Dane Miller with Houston Z. Yes there are many more knowledgeable people out there but these guys are the best and brightest.mparra11 wrote:Ok why on the z1 website it has different gap settings for psi? Because changing the Gap for different PSI is the poor mans tune, it basically alters your ignition timing but its unreliable and shouldn't be done with pregapped iridium plugs one way or the other. What do u mean by tuned? Isnt that like a upgraded ecu? Yes that's exactly what I mean, if its worth doing, its worth doing right, especially when it comes to cars as finicky as these.
win. Win. WIN!NolimitZ32 wrote:
everything-you-need-to-know-about-the-z32-t508376.html
-Do not go the cheap route.
-Do not believe anything Z1 says unless at least 2 other tuners back it up.
-DO NOT RE-GAP IRIDIUM PLUGS. . . .EVER!
-To up the boost you NEED a tune this means either you socket your ecu and get a chip from one of the tuners and install it yourself, or buy a whole new socketed/chipped ecu, or send yours in to get socketed and chipped.
- Not to be a complete d*** but if you are asking these types of questions you shouldn't be messing with timing on your car. The best advise I can give you (because neither I nor anyone else is going to completely spoon-feed you) is read, read, read. Start with basic theory of how all components and processes in an engine work together ie: spark, timing, fueling, etc. Then read through the entire link I posted at the top. Then make a decision based on your knowledge and not what some douche (me) told you to do on a forum.
those are pretty average turbos, you can do much better, the jwt530 or 550bb turbos are probably the best street turbos.CRPZ wrote:I'd get some 525 turbos and make sure everything else is prepared to handle more boost.. I'd say keep running stock boost (8-9psi?) 'till you have everything else situated. Better be safe than sorry, ya know?
OEM = STOCK. STOCK = OEM. Stock boost is 8-9psi. Don't push the stock turbos to 15psi. Buy the correct gap iridium plugs.mparra11 wrote: *Ignores and posts anyway*
