Joe »
https://forums.nicoclub.com/joe-u4941.html
Mon Mar 05, 2007 10:03 am
Many of you remember this problem i had back in november, well it resurfaced last weekend and im going to create a new thread because the last one went OT pretty quickly.
background Series 2 RB25, been in for about 4 years, dedicated track car, have had virtually no mechanical or electrical part failures at all.
problem - between 25-75% throttle, car has inconsistent power delivery. meaning it will begin to pull normally SOMETIMES and very briefly, then hit a flat spot and slow down and remain like that. at 100% throttle there is no power. makes lots of noise, doesnt go anywhere.
what ive tested - boost leak checked the system to 50psi this morning, NO leaks anywhere, replaced spark plugs, recalibrated TPS, redid base ignition timing, checked resistance on engine coolant temp sensor (value changes with temp change too). boost is reading normal (12psi). THERE IS NO MISFIRING. its just flat. no smoke i can see either.
3/6 - replaced fuel pump, still same issue.
I have 11 days to fix this problem.
give me your ideas NICO.
