BigPar »
https://forums.nicoclub.com/bigpar-u30547.html
Tue Mar 06, 2007 7:24 pm
My car has this problem. Use to be real bad when my timing was off, but for most pasrt is gone once I fixed that. Still occurs, but only when 100% throttle from low rpm (heavy load), and sometimes does it when I do a hard pull and hit rev limiter right when shifting, next gear imediately is not there when pressing the gas and spits and sputters until I just lay off the gas for a second then you can ease back into it and drive it normal. I figured my MAF is just maxing out. I'm hoping to go standalone soon, or trying out an safc and z32 maf to see if it fixes the problem. I've just learned to drive around it. This problem doesn't seem uncommon as I've noticed other people making threads about it past 6-8 months.
