blackzenki82's Gold Zenki SR build thread... 56k beware!!!
BlackZenki82
Car: 1991 Nissan Skyline GTR
for some history on this car for those who don't know.... this is a copy and paste from my former NA build threads on various forums...
we all know that i wrecked my car to avoid a deer... so the adjuster is coming by tomorrow to cut me a check for the car, and i'll be buying it back... since i can't retitle it I'm going to use it as a parts car, and for a part out, to try and make some of my money back on the buy back...
with whats left over, I'm thinking of buying this Gold S14 base for $4100 cash with around 85k miles on the chassis and around 70k on the black top, it's needs alot of TLC, most of which i can pull off of my Black S14 that's totaled... mostly interior bits here and there, radio bezel, shift boot, ignition surround, and few minor bits and peices on the inside...
engine runs kinda rough, it must be a a MAF sensor (will replace with Z32 maf listed below, and i have a feeling it's got a to be a vacuum leak somewhere, it idles like it's misfiring on a cyl, but as soon as RPMS are above 1k, it's smooths out great and pulls hard... Also, the seals on the turbo are bad and has no gasket between the turbo and the mani, turbo smokes and has moderate shaft play.. at anywhere after say 35mph, the steering wheel shakes like it's trying to piss it's self and run away, my S14 does the same, just not so bad... more parts of the parts car (i hate calling it that "parts car", and now i will cry for a minute)
Okay done crying, as for the outside as you can see in the following photos, the front panels are pretty much shot, both fenders, hood (which due to lack of fastening the hood pins, flew open and shattered the windshield), and the roof being dented... all of which parts, except for the roof i can pull off of my car, as well as my buddy's parts car, namely hood and fenders... the trunk is also bad, which a tree fell on, it's just misaligned and needs to be replaced, also another thing i can pull of my wrecked S14...
as far as the mods go it has....
S13 Black top SR20DEThks wastegate actuatorgreddy type s bovgreddy profec spec II boost controllergreddy turbo timerApexi safc2Brian Crower stage 2 cams 264/264VLSDbig *** intercoolergreddy intercooler pipingwalbro fuel pumpautometer boost gaugeautometer oil gauge not connectedunderdrive pully setfull 3" exhaustApexi N1 catbackRacing Hart 18" wheelsEibach lowering/race springs, front are heated to lower car for SRB&M short throw shifter with B&M round knob
extra things that come with the car...two coil packssr20det fuel pumpecu300zx mas air flow sensorsr20det cam angle sensorbare sr20det headgreddy front mount intercooler (dent in the bottom)two stock wheels with 100 percent tread
well here's a few shots of the car...
ext
motor...
Apexi N1 cat back..
and now to get current and up to speed....
well guys, i finally brought this bucket home... it made it on a 2hr trip with no screw ups.... the suspension is shot out, the brakes are non existent, and the idle is rough and the starter isn't getting enough ground/power one or the other...
today i went to start the five lug swap, then saw that it had a security lug nut... and i was an idiot and didn't check the glove box so i gave that up (later looked in the glove box and there it was).
so instead i figured i's take care of some of the cosmetic things, so i swapped over my headlights, and light bulbs (silvania silverstar ultras) and my cheap-o fake HID high beam bulbs... and found out that the driver side harness was ate up and i'll have to use the harness from the parts car (the black Zenki), to make it light up correctly (low beam is dim as hell)...
after that i decided to figure out why the shifter was soooo wobbly so i tore open the center console, and got in to the shifter, found out that the upper boot had no screws holding it down (why do i think this is going to be the story of this car??)... after i removed the upper boot, i realized that at least it is a true V2 B&M shifter... with no boot... again, pulled from the parts car...after removing the shifter lever, i found out why it was so wobbly.. the lower bushing on the ball was missing, so since the car came with the stock SR shifter, i took it off and swapped it out... easy, got the boot on, trim all back and went to put in my radio bezel and another mess...
found out the crappy CD player wasn't fully secured and was actually hard wired into the original harness (weak sauce) and that wasn't something i wanted to get into... the SAFC is wired through the back of the vents in between so i cant remove the vent panel with out breaking it (two of the locking tabs are already broken anyways so when i get motivated i'll finish her off). so i reinstalled everything, got the radio bezel back on in a half way recognizable fashion, and even rewired the cigg lighter (I'm a smoker and use it, just not the ashtray, which i NEVER use)... got it all pieced back together and for now, called it a night... i had a long drive on shot suspension and a turbo that as soon as it started boosting, smoked out the car bad... had to ride most the way under 30% throttle (i know that cuz the SAFC told me, it is good for SOME things...) which was kind of a pain... i mean come up, you scoop up a turbo car that's most likely pushing 220 to the wheels and you can't even romp on it...
here's some pics, there will be many more to come as i document the resurrection on this car...
just got home, look at my two babies, popped the hood to get ready to jack her up...getting on what i thought was the five lug swap...just a quick little motor shot... first time boosting... EVAR!!!replacement turbo, Garret GT28...r? dunno... sez .63 AR... brand new, scooped it up for $350... Ball Bearing... woot woot..
ADD: i just went outside to look at this kids "custom downpipe" and it IS nice... but it's only held on with one bolt... no wonder the smokey turbo smokes all under the hood and in the car... ARG!!!! time to do more work...
at least i ended up getting it for $3800
that's it for now guys, stay tuned for the rebuild of this heap.... more too come and thanks for reading through...
xrproto07
Car: 96 S14 zenki
Dam baller status bro!
Not one but 2 pretty clean Zenki's
And a pretty badass price for all the stuff that came with it and extra stuff
you got
IDRFT95S14
Car: 1995 Nissan 240sx SE
heeeell yeah.... nice zenki's man
BlackZenki82
the seats in the new40 are the dark gray color, single tone, and at first i was like hell yeah, till i saw that the fabric was coming off of the seat foam.... looks like i'll be swapping in my like new Black zenki seats with their two tone color... UGH... got to be put together, not raggedy.... i'll be out of town, down in St. Pete till Friday, but this weekend will be a MASSIVE rebuild day.... i'll be custom fabbing a turbo elbow to get this GT28 on there ASAP to fix the smoking.... it'll mostly be a weekend of putting everything back together, and tie up loose ends that previous owner got, what looks like, half way done, and called it finished.... just getting it right.... then comes engine... full maintainance, possible re wire in some places (starter isn't getting enough juice, need to figure out why), check for boost/vacuum leaks, get P/S high pressure hose situated... 5 lug swap (not to sure cause i kinda like these racing harts.. i dunno).... MOST DEFINITELY NEED TO GET THE BRAKES IN ORDER, they are in horrible shape... like to the floor and it's not stopping.... no pads, the base rubbing straight on the rotors... rear caliper on the passenger side has a leak ( brand new OM rear calipers on the parts car woot woot).... so with the five lug swap my cross drilled and slotted rotors with ceramic pads will get swapped over also.. to get some stopping power on par with the motor...
IDRFT95S14
well you got some work to to do man, my car has a slow starting problem too, but it has to do with the grounds i migth get a groundn kit since i relocated the battery its been doing that sh1t but it runs fine
BlackZenki82
IDRFT95S14 wrote:well you got some work to to do man, my car has a slow starting problem too, but it has to do with the grounds i migth get a groundn kit since i relocated the battery its been doing that sh1t but it runs fine
same friggen problem.... battery relocate, ****ty ground, let me know how you fix it... gotta to a rolling start to get the starter to turn... pain in the ***...
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
for the canopy/tent. Got exactly same one with the black color car, but it's a S13/RB20 haha instead of S14/?.
what the fakz was your gold zenki in a fire or something?????, why is the rad core support all black and gold color.??????
IDRFT95S14
ill let let you know how it turns out ill probably do it some time this next month cause i been really busy at work but yeah
BlackZenki82
lol, i'll be doing mine ASAP, so i guess i'll let YOU know how it works out and what i did to remedy the issue...
placham wrote: for the canopy/tent. Got exactly same one with the black color car, but it's a S13/RB20 haha instead of S14/?.
dood, i just bought this car today, for $3800 as a project car... the rad support has more wrinkles than old uncle charlie... and the "burn" **** is from the welded hood pins and god knows what else... i'll be cleaning/straightening it all out... just you watch....
i'm posting on this forum (first real thread on this forum too), as well as the others, just mostly copy and pastes, i like to spread what i'm doing, as i'm doing it so maybe someone else can learn from what i do, no matter how tedious it may seem, even just painting a rad support... so if you're interested, stay tuned guys, i've only gotten started on this one....
Philipio
Car: 96 240sx, 96 Miata
Looks like you have your work cut out for you. Good luck.
placham
Oh I see, $hit 240sx are hard to come by these dayz, especially unmolested ones haha. Got mine half/a$$ed it was ready for junkyard, but I saved her. So wait your black S14 is totaled and it will be unable to be registered ever again. Can't you apply for like salvage/rebuilders title or something???
Here's mine, if your into S13's (coupe by the way), hope it changes your mood from wrecking your Black S14. LOLhttp://forums.nicoclub.com/zer...think
BlackZenki82
fixed ****....
brakes (HOLY CRAP, you should have seen the right rear caliper, pics coming soon)suspension (heated springs, blown OE shocks)driver side window and and switch assemblycracked and leaking (UGH) stock oil catch hoseghetto *** power and ground wires, rewired and fixed, car starts with out pushingre did vacuum lines for the Greddy Type S BOV (missing a vacuum line to the intake)adjusted trunk so it sits correctly, and not unflush
so after the brakes (replaces right rear with new or 1k miles caliper) and the suspension (sourced the Tein S-Tech springs and OE shocks from the black car) the car actually rides like a half way decent car now... and i can stop it without pushing the pedal all the way to the floor.. awesomesauce. also both driver and passenger windows work with no problems, car will start without having to roll it forward or backward to help the starter along (bad power/ground).
quick story, as stated, the oil catch hose was cracked, and he had the other end of the "T" on the PCV(?) capped off, no filtered, so while showing off for some friends, the oil pressure built up enough to fill the catch can, and push the oil dip stick out of the shaft, hence, blowing oil all over the engine, road, under car... just a horrible mess... so next day i got to advance, get a new hose and oil breather filter, problem fixed, and the car doesn't smoke NEAR as bad as it did when i first got it, even under boost... drove it from ST Pete to gainesville with almost no smoke... awesome.... it's the little things guys...
so far that's the update.... much more to come tomorrow when i replace the half blown stock T25 with a brand new Garret TB2804 for a Pulsar GTIR (need different exhaust housing first). which i may be getting free...
no pics tonight, which as most of you know, i usually post em, but i'll get some tomorrow of the progress, different ride height, and cleaned up vac lines...
Clawhammer
I can't believe I haven't seen this thing yet.
BlackZenki82
well it's Saturday the 29th and once again, i got more work done on this heap, it's getting out of heap status and graduating to "pile" status...
things i did today....
removed stock T25 and manifold (bottom mounts are a bich)did a test fit of the TB2804 on the stock mani, not sure if waste gate will transferreran some messed up vacuum linesreplaced beat and worn gray Base S14 seats with my nice SE'sfixed driver side kick panel (was hanging open with misc wires)replaced F'd steering wheel with perfect one from parts carreplaced steering column trim (unscrewed, adhesive slag, just nasty)replaced Base headlight, wiper lever switch with SE unit, very nicereplaced black faced Base gauge cluster with white SE clustertucked boost gauge wires in dash (we hanging lose between dash and door)replaced driver side door sill (only two tabs were holding the old one on)put the little button tab on the door panel by hinge (it's the little things)got the ignition trim put on (was missing, not anymore !!!)tucked misc wires that were hanging below the dashREPLACED WINDSHIELD!!! no more shattered glass
just kinda started getting the turbo swap started, wating on a 5 bolt exhaust housing for the TB2804, and will be installing, hopefully i can find a way to mount the HKS adjustable waste gate to the new turbo, don't know if i can though, UGH... got a lot of the interior replaced, and fixed, to get it looking like a halfway decent car on the inside... driver comfort and all... I'm loving the SE gauge cluster, the blue LED upgrade in it matches the turbo timer, CD, player, greddy profec B II and will match the Auto Meter Cobalt gauges i have and will be installing as soon as i get a matching boost gauge and 3 A pillar gauge pod....
i'll let the photos do the talking from here....
pulling mani and T25turbo comparison, TB2804 on left, stock T25 on the right...getting the windshield taken care of... old guy was the installer lolstarting the get the interior FIXED....new old seats... miles better than base seats....finished and CLEAN!!!for those who may have doubted how bad the right rear caliper was...welcome to my office....
well that's all for now guys, more to come tomorrow, and probably the next day.... hopefully i can get my turbo problems situated before too long so i can get this thing back on the road.... i dread driving that big a$$ Tahoe around all the time....
Stay Tuned.....
Clawhammer
Don't hate on the 'hoe!
BlackZenki82
Clawhammer wrote:Don't hate on the 'hoe!
same 'Hoe that pulled your S13 outta that ditch... yeah i guess i can't hate on it too bad...
Clawhammer
<3 the 'hoe.
mRodiek
Car: Stock Hatch
nice build so far man, lookin forward to seein what you dowhat are your plans for her anyway?
BlackZenki82
plans are autocross/road racing and SOME drifting...
well guys, once again, Sunday the 30th, i did more work...
it all started with getting the interior in order, to match that of a REAL S14.. so what i did as far as inside the car goes, is pull the broken AC control bezel out and replaced with with my perfect one from the parts car, having to drill a pocket for the SAFCII wire..... since the CD player was ****, the one that came with the car, i replaced it with my Pioneer DEH-6800, a nice unit, kinda old but still kicks ***.... after i got that in, i cleaned up the locations of the turbo timer, and the greddy profec B spec II, just to tidy things up,. i also replaced the base rear speaker cover (damaged, 2 tabs holding it in) with my SE one (perfect condition) so the rear is deck is situated.. after all was said and done i topped off the gutz with the OEM "240SX" front and rear floor mats... car now looks like a CLEAN car, as afar as the interior goes... you should have seen it before hand....
after that i moved to the trunk, yet again, what a mess... i had to replace all the screwed up linings, trust me, it was bad, with the perfect ones from my SE parts car, pics below... you'd be surprised how much time it takes to get all that crap swapped... i also, while in the rear, replaced the dented and screwed up trunk lid with my black one from the SE, looks kinda cool, especially with the smoked zenki tails, not to mention it sez "Silvia" on it... you can't imagine all the hammer work i had to do to get it sit right (car was previously in a rear end collision, thanks for telling me seller...), anyways, it sits a lot better now, had to beat out the rear bumper cover support to get the bumper lines to match up with the tail lights correctly...
other than that, not much else was accomplished today, even though it took me about 4 hours to get everything right, hammering, screwing, unscrewing, blah blah... at least now the trunk and interior is presentable... more photos after the detail...
pics....
radio replacement.... crappy DEH-3800confusing cluster**** of wires.... turned out plug and play, love pioneer..AC trim in, pioneer DEH-6800 installed and slighty relocated boost controller..redone and cleaned up trunk... needs to be detailed i know... should have seen it before..UGH!!!!and the black trunk with smoked Zenkis, sorry bout bad quality, pics taken at night...
baratatat came by today and pulled the good ol KA out of the parts car, got it done, was a process, but got it done... here's pics of the engine removal... i helped a bit... lol
and for a BONUS of epic proprtions.... while brian AKA baratatat was pulling the motor the first time, the valve cover got hung up on the firewall and lifted the whole car up, and since his hoist was missing a bolt, it swung the car off the jack stands and resulted in this EPIC FAIL... someone photoshop plz.... i mean the car was sitting about sideways in my carport... loves...
other than that, that tops it off for today.... tomorrow i'll be seeing turbo charlie about my TB2804 and getting everything i need to get it on my SR, if it can without spending an a$$ load of money, but like normal, i'll keep ya'll in the know...
stay tuned...
Clawhammer
Hope those fenders are still pretty!
BlackZenki82
Clawhammer wrote:Hope those fenders are still pretty!
fenders are golden, and the side skirts are ****ed so no worries about being molded/screwed on woot woot... might claim the driver side fender for myself... or get EZ's... either way...
BlackZenki82
couple new purchases, i just scooped up and Auto Meter Cobalt +/-30PSI 2 1/16 boost gauge to match my cobalt series oil pressure and A/F gauges, as well as a 3 pod A pillar mount to install them in....
the new gauge as well as the pod should be at my house in about the same time my custom/upgraded Garret T28 is ready on Tuesday of next week.... sweetsauce, will of course post photos and ****e...
veebee
Car: 2005 EVO VIII
hi marshall
BlackZenki82
yeeeeeeeeeoooooooooo dustin! whats up bro?
liking the new busted whip so far?
veebee
Car: 2005 EVO VIII
yeah man it seems to be coming along nicely. looking forward to seeing the finalized product(s)
BlackZenki82
**** will be dope, gonna top it off with a two tone paint job... black trunk, roof, and hood... everything else, stock and loooooow once i get coilovers...
BlackZenki82
Well, looks like i finally have all my gauges ready, the auto meter cobalt -/+ boost gauge just came in today... just tore open the box like a kid at Christmas, and it's pretty damn cool looking IMO...The blue of the gauges will match my blue LED gauge cluster upgrade, my GReddy turbo timer, and my GReddy profec B spec II boost controller, APEXi S-AFCII as well as closely matching my pioneer DEH-6800 head unit..
Just a few more things waiting to come in the mail before my turbo is ready...
A pillar 3 Gauge podT28 HKS waste gate bracketMegan Racing Stainless Steel bottom mount SR manifold
Will post updates as they come along ladies gents!!!
BlackZenki82
as another update, i got the power steering lines fixed on the SR, thank god for a parts car to source all this stuff from, makes my job a whole lot easier, AND faster, luckily enough, i already had the turbo out, and that made clearance to get down to those lines a ZERO problemo... so YAY for power steering!!! next up, sway bar, and brakes, cross drilled and slotteds here we goooooooooooo!
Clawhammer
You redrilling your rotors or manning up to 5 lug?
BlackZenki82
tim has some "brembo" rotors.... 4 lug... no need to "man up" to 5 lug... i got forged 18"s 4lug, so alls gravy... just gotta rock some spacers is all....
