ADiamond75 »
https://forums.nicoclub.com/adiamond75-u25693.html
Tue Aug 22, 2006 5:43 pm
I had planned on doing Pauter or Crower Rods
I am also going to use Wiesco or CP pistons .... unless someone knows of a better brand. Which manufacturer is known for building the most durable pistons and rings ?
Good to know about the cams ... I didn't realize Nismo sold the 248 cams .... anyone know where to find them at a good price?
Also good to know about sleeving the block, I think this will definatly be the way I go.
And yes, this is going to be a long time project, I have planned on having the car down for a year, maybe more while I do the build. Basically all my extra cash will be dumped into the car for the next year or so.
I guess Garrett (sp?) turbos would be the way to go using a T25 then, unless someone has a better recommendation.
I though the stock CR was 9:1 not 9:5:1 ... I wanted to run slightly higher than stock CR regardless of turbo or SC. I want to do this to add alittle low end torque and to make the turbo less anemic.
So the AME EMS is a piggyback? I was under the impression that it was a stand alone that 'replaced' the stock ECU. So all my sensors and features will continue to work the same way then ? (i.e. - my check engine light won't come on unless there really is a problem, also, the check engine light is an imediate fail of emissions in Texas)
Also, do any of the turbo manifolds come with the port for the EGR, or is that on the down pipe? And will the EGR system be able to be left intact with a turbo ?
High pressure oil pump? Where and how much? I have only seen the stock replacement and would love too push more oil. I like the lube!
Also, I am planning on using a crank scraper and windge tray (sp?) as well as balancing the bottom end and porting and pollishing everything that it can be done to internally (i.e. head, intake, am I forgetting anything?) ....
I was also thinking about using Iconnal (sp?, yes, I know, I am a horrible speller) valves, is this nessisary for a 10psi turbo, I don't want to go overboard, I do it all to often as it is.
And yeah, I tried messing around with the search utility but wasn't finding all the answers to my questions, and knew that more would arrise as my specific questions were answered, so rather than starting 10000 threads for each question, I stated my goals and all my quesitons as a way to start the discussion rolling in order to create an open dialoge that could be followed for my specific build.
Thanks for the replys guys, keep em comming and I'll come up with more questions.
Modified by ADiamond75 at 8:54 PM 8/22/2006
