wankelTII wrote:thats part of it, but someone did explain also that boost of any kind adds more air than an N/A engine would be able to draw in, reguardless of CR and more air and fuel is what makes more power.
There is alot of incorrect info in this thread and i dont have the time or the patience to explain everything.
To the post starter, it sounds like you may be focusing too much on small things and trying to cut costs in the most important areas. If you want a reliable car that is finished one day, then stick to the basics, and keep everything as simple as possible. If you are going to build the engine then leave the stock compression, stroke, and bore, or leave it as close to stock as possible. Its a 2.4 liter cast iron block, why would you want anything more than 2.4 liters out of a 4 cylinder and why would you want to waste your money sleeving something that is really strong already? Use forged internals, high quality bearings, and talk to the company that you choose to buy your pistons from about coatings to reduce wear. Keep the head work mild also, and look for a turbo cam, i think HKS might make one. You said you didnt want lag, but then you said you bought a turbo off of a diesel truck? You need to sell that thing and just buy a GReddy turbo kit or something that comes with tuned fuel management. If the stock kit isnt enough for you, call up GReddy and talk to someone there that knows what they are talking about and see if you can get the kit with an intercooler and an emanage ultimate (with harness adapter) tuned or at least with a good baseline. If you dont take this route then save a BIG chunk of money for tuning because it takes like 10 hours or more for a professional to get a decient tune for the street when you are starting from scratch. Thats alot of dyno time and alot of money.
Thanks for the reply. I have already bought crower rods and have a set of 9:1 wiesco pistons but will prob go with some arias 8.8:1 pistons (better rings from what I have heard) and the pistons came with the rods, so i can always sell the pistons. Money is turing into not as much of an issue as far as tuning goes, its now officially a project car and if it take 3 years to get it on the road so be it. I am also looking into the FullRace manifold cause I can't find anything that will put the holset where I want it. If anyone knows of a less expensive one that will be topmount and keep the turbo away from the brake booster let me know ( the full race one is $1400).
From what I have seen from several other threads and talking with two people that have ran the holset, full boost is at 3500 rmps, which isn't bad if the motor is built to rev to 7K or beyond. I also have some other things I am currently researching to make the power band where I want it (i.e. cams with mid power curve, custom intake manifold, the fullrace exhaust manifold, good porting)
I am also looking into having the block, head, manifold, downpipe and pistons heat coated to keep heat down low and out of the engine bay, buddy of mine that builds race motors is heading up this portion of the build for me (said something about aircraft heat coatings but that is down the road so more details later).
Overall, in a few years I should have a nice little toy, maybe sooner.
But like I said, please post up more sugestions. Also, if the holset turns out to be to laggy, it could be a VERY easy part to replace considering all the other money I am planning on spending.
I will probably not sleeve the block anymore, looking into other fun ideas ... anyone know who makes an aftermarket crank out of crazy materials (light and strong)?
I am also trying to find an RB20 flywheel for under $400, its the next thing I'm buying (clutch setup) If anyone knows where to get one let me know, I may have found a stock one, but an aftermarket lightend one would be nice.
