KEMP wrote:Which MLS do you prefer i have had cometic, which have not sealed for me, then greddy, which was fine before it melted and blew between 3&4.
Im thinking of going with the ACL... any objections?
also any idea why my head melted? and why it blew a gap in the head and head gasket? it looked as if someone polished a path between cylinders... its plenty rich, and there are no DETONATION marks signs, or any other melting on the head in any other cylinders, i want to make sure this does not happen again, i believe there might have been a flaw in the head, like a scratch or a bur...?
Listen to me and listen to me good. You ask for the advice, it's yours. But remember it comes with criticism, so all you fresh noobs that think you know everything, please do not read as you already know what I'm going to say. KEMP my boy you are a hard-headed joker, but I do commend you for being honest and telling us the truth; for that's the only way we'll be able to properly diagnose your dilemmas.
Now, there's three good reasons why this happened. The first one is the fact that you are running waaaaaaaaaayyyyy too much boost on this engine without the proper tuning. Before you say anything, how many times have you messed-up your motor? And do you want to continue this trend? Whomever is tuning your engine or whatever you're using to tune it, isn't either tuning it correctly or the device you're using isn't being used properly. Just because it runs doesn't mean it's in the condition to go hump 25 psi of boost.
The second reason is possibly an insufficent fuel flow source which could be a bad injector, maybe an injector hiccup under high boost/high load applications. Or maybe it could be a fuel pump that wimps-out under high loads or a faulty regulator. Or just maybe, your fuel pump doesn't have the sufficient amount of voltage it needs to keep the pump pumping to meet your boosting demands. Remember, just because you bought stuff new doesn't mean it's supposed to always work correctly. I know this because I put a brand new autometer pro boost gauge is a current car I'm working for a customer and the damn thing would only show that the engine/turbo combo was producing 1psi of boost. That thing was a straight-up failure and I'm @ssed-out of $50+ dollars. It wasn't the first thing that has failed one me and I'm sure it won't be the last either.
The third reason is possibly too much timing which semi-goes back to tuning. If I don't share anything else with you guys and girls, I truly want you all to know that this engine doesn't like too much timing. And if your SR buddies or KA buddies treat it like such then "Pop goes the weasel".
I know it's rough, but I don't have any other form of delivery for you. You see, I too used to whack engines, melt heads, pistons, and spend a lot of money, so your situation is not unique to me. My advice is to pull the engine and start over again. Be suspect of the things I've mentioned and eliminate them not with your guessing and assumptions, but hard-core facts. I wanna see you guys succeed, but if you are reluctant to take the advice given, you are on your own.
Dee
