dash wrote: sxoc has more powerful running CA examples, and suggest rod change before 400hp.Maybe based on 'their' experience, as they have a lot more track car samples.Could be "playing it safe", different dyno ratings, dunno.
"400hp" can come with varying torque. I'd think that makes a difference. E85 too ?Same way we can look at how a clutch is rated, while it's Tq that breaks parts.
"use" factors heavily into the equationMobne dyno'd 700hp still on CA gearbox, but we'd hardly say this 5spd is '700hp capable'. Bolt on slicks, 2 step, dead hook, picture changes drasticly I'd imagine.
Timing is everything ! If they tune on the edge, the results will be as such and we'll toss the engine's death up to trial and error/R&D. I agree that with slicks, a few other forces come into play, but one must understand too that this drive train is not meant to be launching your car like you're John Force, either. You may get away with "tuning on the edge" for a while, but you will get caught. I have 400+whp running around that's doing it extremely reliably and with A/C and P/S. And I'm not talking about changing programs to reach 400whp; but an everyday setting at 21psi of boost and 93 octane.
My personal 240 w/CA does better 300+whp daily and I don't touch it; but then again, I don't drive it much either. It's actually getting a new manifold made as we speak because that cheap ebay exhaust manifold has it's limits and will fall apart even after modification. So in closing, if your car is not a dedicated track car, it should not be bending rods and even then. The bearing should suffer before the rods starts changing shapes. Just my opinion though..................
Dee
