Oh Simmode, this is not one of my hellaflush bashing posts, lol. I have a valid point this time. 18x11's with super sticky 295's sticking out a full inch past the edges of the fenders are NOT what you would use on a car you were trying to push to 400kph, which is what they intend to do with this car. All that set up is going to do is drive up the drag coefficient. You don't need max traction for a max speed run, quite the opposite in fact. Also, those advans are only rated to around 280kph and Nardo is not the smoothest track in the world. Are you familiar with the Nardo test track?
Its one endless corner, which puts an incredible amount of strain on the structure of the tire, if not the actual grip from the rubber. Check out Top Gear UK, series 18 episode 1 for an idea of what driving around it at ~330 kph with proper tires is like. Looks scary as hell, very bumpy.
Honestly I like the build, but the car is definitely not optimized for what they intend to do with it and it might turn out to be a total disaster.
