Well I haven't really done an update on the build thread recently...But believe me I have been hard at work day in and day out on the car.
Been running over and double and triple checking the charging/starting/interiror harnesses to make sure everything works. Last thing I want to do is get the motor in and then not have it crank because I forgot a wire when I re-did the harness. So far I must say I've suprised myself. Turns out everything actually works....after you put in all the fuses and relays (yeah trouble shot the headlights not opening for like 2 hours and made sure every connection was good until I remember I took the relays out.)
We did end up making a bad a** insert for my glove box for the relocation for my underhood relay box/distribution box. Looks real good and I'll have some pictures up here later this week when I get around to it and after I get it back in once I'm 110% the wiring is all good.
I also got a track seat, a Momo SuperCup. Reasonably priced, very comfortable, and most importantly, a little more forgiving to my fat a** getting in so i don't have to worry about staying on a diet to drive my car. We then immediately stripped the cover off the seat and wrapped the back of the seat in 3M carbon fiber wrap to match the rest of the interior accents. Which turned out AMAZING. again, pictures of this coming as soon as I get the seat rail adapter in, hopefully this week.
Also finished welding up a custome rear bumper support since the factory one was no where near close to fitting. Didn't do a tubular since we don't have the material at my shop to bend it, so we just did it with some thick square stock, but it turned out really well. I'll have pictures of this when it comes back from powder coat.
I also did a bulb housing replacement:
If you're like me, sealed beam lenses sound like a pain in the a** to replace every time a bulb goes out. So you can go for the chincy E-bay ones that look like a set of pepperoni nipples through a wet white t-shirt on antartica (pause for mental image if you do so wish)...or you can go for the better looking, but slightly more expensive HELLA coversion kit like I did.
The kit is way better quality than I expected honestly for the price. The whole housing is very solid, and the front lens is GLASS, not plastic or something cheaper. Very solid feeling piece. It then just has a whole in the back of the lense that you can purchase to accept either a 9004 bulb, or in my case, an H4 (many more applications available for the H4 of course)
The HELLA kit comes with a nice little bootie to cover the bulb to resist corrosion on the bulb connectors, very handy. It then plugs directly into the factory headlight wiring. Absolutely no cutting, splicing, anything. Just plug it right in:
Then, if you're anything like me..you realized all the bolts holding the thing in were rusted when you took the bulb off....so I drilled out the old holes so I could fit in my weapon of choice on my front end: Stainless hex head pan head screws for looks....
Finally, you put the housing back on...and BAM! nice brand new OEM looking housings with a lot less rice than the ebay knock offs:
So as you can see, with a little love on the headlight cover, you can make your whole headlight assembly look brand new for about 100 bucks and probably only about an hour of your time. Yes these are my original 92 headlight covers, just prepped correctly and re-sprayed in a satin black to clean them up. Very worth while if you have a couple bucks to clean your car up and want a nice easy project for the weekend.
Ill be back with upadted pictures this week on everything else. thanks for tuning in.
